Hey pop, maybe this will do for what you're looking for:
Feed legs for 1.2m Antenna
That particular set is for the 1.2M transmit/receive dish. When you ask make sure you get the set for the receive-only dish.
RV1pop, be sure to order the correct legs. As ACRadio mentioned, the ones in the links above are for the transmit/receive dishes, and do NOT resemble the ones on the dishes you and I have. The legs you want are round poles on both ends, one end is not flattened as in the pics in the above links.
The attached picture shows similar poles on my 1 meter Channel Master. The 1.2 uses the same style, but a bit longer.
The legs for the 1.2m dish from Future Vision are the correct legs for his dish. I have bought several from them and they all were correct. The feed support legs for a 1.8m CM dish has one pole with a flattened end.
You have a wonderful, hard working, observant son!You know pop my son would have eaten you guys out of house and home if we would have stuck around longer.It was great meeting you and your wife. What a great couple.
Thanks, phlatwound, I have the conduit and the bender. That is what I was going to try to do. If the angle on the bottom one is the same, Then I can find the hot spot and bend the side ones to fit. I have a GOOD 1M to copy if they are the same.
