I have fabricated a magnet wheel for a Birdview H-H mount and have been using my G-Box V3000 to power the motor and detect the pulses off the reed sensor.
After a several tests I got the "E--2" error message on the display, figured I had a problem with my sensor circuit....checked, no problem...then thought the sensor itself may be bad but didn't know how to test it, and I didn't have another handy to switch it out. The motor wouldn't even move slightly, like it would if it had an issue with the sensor circuit.
Tried to "Reset" via the remote (several times) to clear the memory and also unhooked it from the power, no help.
Then decided to hook it up to another BV mount (with the 1.2 Prodelin on it) that I have been using it on.....nothing, still get the E--2 error display.
Looked in the User Manual and didn't see anything, then went to the Sadoun website and found this:
"E2 Message on Display:There is only one error message -- E2 message for GBox. E-2 Message means NO PUSLES detected.
Possible causes:
I believe I'd verified the first 4 of the items in that list so I opened the case up to look for the fuse. I'm definitely not an components-level electronics repair guy, but I don't see anything that is obviously a fuse. If it doesn't look like an old or new style automotive-type fuse I probably wouldn't recognize it anyway, that is what I was looking for.
Has anyone replaced a fuse on a G-Box, or can you give me any direction on this?
here's pics of the G-Box guts and a couple of my magnet wheel caper, to boot.
Possible causes:
[*]Re-check the wiring connection from the actuator to the GBox
[*]Make sure the actuator is not stopped due to Mechanical Limit.
[*]Check if the Reed Switch Sensor in the actuator is broken.
[*]Check if the Motor is broken.
[*]The Fuse inside the GBox might be broken."
