Officially LOST
iBoston
2,607
2,156
North Central
I'm ready to pay someone to setup this dish. I am so lost.
I can pull in FTA between 87 and 123, but it only seems to be strong transponders. I can get strong signals all the way to 125 but those are encrypted channels. For example, there are many transponders that i can not pull in from various satellites.
For example, i cannot receive :
Florida Channel, The (DVB-S2) www SES 2 12044-V 3200 49 60
Louisiana Public Broadcasting 2 (DVB-S2) www SES 2 11808-H 11150 65 68 WLPB-DT2
Louisiana Public Broadcasting HD (DVB-S2)
But, i can receive 'The Patient Channel' from the same satellite.
This is the case on many satellites. I have TWEAKED to till my fingers are raw. no matter up or down, left or right, i cannot seem to get any stronger of a signal to pull these channels in.
It doesn't make sense. I can pull in channels all along the arc, but i cannot pull in certain transponders.
I don't know where to go from here...
Ps. Have a 1 meter dish.
Please help.
Since you hitting satellites along the arc i would think its something simple .
maybe skew is off or if your lnbf has the ability to be loosened and moved foward or back in the holder these should be two simple adjustments to try .
and we all get frustrated its actually one thing why i enjoy tuning satellites i think i'ld rather play with the dishes than watchen the channels ( unless its football season) . :)
Reactions: . Raine and Elkview
I'm not the best to give advice...too new to the hobby, but from my little experience I found that the DVB-S2 transponders are tough to get in. It took me a while. I had a hard time blind scanning those channels. I manually added LPB and Florida. Stick with it. Someone will be along to give some information that makes sense.
Reactions: northgeorgia
Skew is at 0. I've moved it all the way forward, and all the way back at different times. It didn't seem to make a noticeable difference, but, ill give that another shot tomorrow.
I have attempted manually transponder and channel adds. I don't seem to get any signal - For the Florida channel, i get Intensity 45, Quality 10. But, i get 13 channels on this 87 successfully. Also, It is not just DVB-S2 transponders i cannot receive. I checked that after i read your message.
LPB goes blank every now and then, so those channels don't fret over for now, they might be blanked out for sports feeds. I don't have a Ku dish pointed there right now, so I can't check if they're up right now or not.
If this is a motorized dish, your skew should be set to zero, if it's fixed, then you can get all your settings for your Lat/Long, skew, Azimuth and elevation, etc, for fixed and motorized dishes here: http://www.dishpointer.com/
Is it fixed or motorized and what receiver are you using? What LNB/LNBF?
Are you getting all the satellites, or at least the ones watchable from your location that aren't blocked by trees, mountains, obstructions? How about 72W? I think I would begin to check the motor's elevation/azimuth, possibly the dish elevation too-sounds like a tracking problem with the motor setup.
I can tell you that receivers can make a difference. I use Amiko 2 which currently is bringing in a solid signal for LPB. Florida Channel is extremely week but I still get a stable picture. I also use a Traxis 6000 HD when I am working on my dish setup. The Traxis has a hard time finding those channels.
What's the best receiver to use to get the HD channels, and all the video / audio formats including AC3 etc.
Motorized
I have very limited experience with receivers. Most have referred users to the Amiko mini HD SE. I am waiting on the new Amiko 3 before I decide. I've been wanting to get another receiver for a while now.
I've used both and both work but the Titanium as proven to be more stable in dealing with S2 signal. That is based on my experience.
