Kijiji, eBay, and Craigslist dishes for you to take a look at
This is my setup but was wondering if I should get for future use
TEK2000 7.5ft mesh satellite dish with Venture Manufacturing 24" actuator, Motek V-Box II positioner with remote and manual, WS International DMX 741 C/Ku dual band LNBF with 22 KHz band switch. Digital inclinometer included for dish set up and WS International SF 95 satellite finder. $275 for all, pickup only in Madison, Wisconsin.
Yes, it is undersized for complete c band reception but posting it anyway as some members are limited in the size dish they are able to install and many are limited financially. It is a great deal as long as they keep in mind it is not an optimum setup for reception. :)
P.S. Since the description also states 2.1m, which is actually 6.89ft, I would make sure exactly what you are buying beforehand. :rolleyes
Winegard 10' C-band Dish (BUD) - $100 (Oak Park, CA.)
Southern California near Thousand Oaks. One panel has a tear that has been repaired.
Well at least it does not freeze there, which does cause the water caught in the bottom rim to blow out
Toshiba TRX-2220 satellite receivers and other Toshiba's are great movers highest quality made in Japan.
and will work many years after the china crap goes to the recyclable bins and the stuff they are sending just gets worse daily. imho
I had an ancient EchoStar I used as a mover that finally died a year ago. The DSR22 I was given with a good dish, c/ku feed horn. and actuator comes on but I can't get it to do anything as it's looking for a satellite signal to download from that is no longer there.
The Toshiba ird I have is only getting errors from the mover.
Guess I'll have to move my dish the hard way with a 12 v battery and reverse switch.
Reactions: FTA4PA
ADL Cband PF 3.7 to 4.8GHz single feed +scalar
unimesh 12
