Latest Update at my Satellite Station
one_db looks on top of it. 12g landscaping power cable from Home Depot, Lowes, etc. will do for actuator power at quite a distance.
Box store coax bugs me. Although all of the amplification of the signal is done at the lnbf. And pushes a good signal that is easily handled by 3 GHz coax. I would expect that everything will be buried in the dirt. I'm more focused with dB loss/100 feet like you will see from the likes of Belden and the others who provide a specs sheet. I'd stay away from the cheapest, but the most expensive isn't a need.
Just don't use screw on F connectors.
Actuator sensor cable needs to have a dedicated shield. 2 wires plus shield for reed switch actuator sensors. 16g seems to work just fine here. Stranded, of course.
Run it in PVC or black poly pipe. PVC is okay because you can run the cabling through each section on the ground first and couple them later. For a long run in poly pipe the good old string and baggie tied to it and a shop vac on the other end will give a pull string. Maybe pull two strings and leave one inside for future use. Use nylon or something that doesn't degrade over time
It's great getting all this good advice.
My motto when it comes to most hobby activities, especially satellite stuff, is best explained by this clip from Apollo 13. In summary, use what you have to accomplish what you need/want.
Square Peg in a Round Hole
Since the VBOX7 has been successfully acquired and is confirmed en route to me, I will remove my Von Wiese jack now, open it up and see what it looks like inside. I might try moving it with a power supply just to watch it move.
Reactions: FTA4PA
I'm always on this. A protective measure. Remove the gearbox first and see if you can turn the actuator shaft by hand.
Then power the motor (count the output shaft turns so you can reverse the motor leads and get it back where you started).
Doing so will keep you from powering the motor in a stall and save the limit switch diodes from shorting or opening due to over current.
Reactions: FTA4PA
I'll keep this in mind. I decided not to use my (good) power supply that's the heart of my radio station. I'll wait for the VBOX to arrive. The Von Wiese is on my work bench waiting. It actually appears in good condition after I wiped the spider webs off.
Added: I tried to loosen the nuts on the Declination bolt. No movement. One appears rusty; the other doesn't. So I coated them in PB Blaster to leave overnight. Maybe they'll budge in the morning. Otherwise, I may have to live with the 44 degree declination setting from Nova Scotia.
What I Found:
Reactions: FTA4PA
What I Found:
Looks like mine, the "eye" bolt had broken off, I figured out through trial and error at the hardware store that it takes a male 1/2"-20 thread to a 1/2" bore eye bolt, cheap on amazon: Amazon.com
Reactions: FTA4PA
A good soaking in penetrating oil. Some raps with a hammer. A heat with a torch and quench and more p. oil never hurts. Wiggle-wiggle!
Reactions: AZ.
This stuff works great. Make sure you use it outside though. The smell can be overwhelming if used inside....
Exactly what I'm using. It's good. Hauled it across Canada when I moved since it loosened the mount bolts years ago and impressed me then. Even outdoor it smells bad.
Yes, one of the last revisions developed of the Vbox. Heck of a good price for a NOS unit. Buy it if you haven't already done so!
I received and am looking at this item now with my own eyes. Though the box appears well used, the AAA batteries are still sealed in plastic as is the remote control. Everything appears brand new with no surface scratches at all on the unit itself. Plugging it in, the unit powers and appears to work correctly. Read your facebook ads: you never know what you'll find!
I tried connecting the VBox7 directly to the Von Wiese just in case I might be lucky again and it might move the actuator. Nothing. 'Err2' resulted on the VBox7 display. Same as when nothing is connected to the box's sensor input connectors.
So I measure 0 ohms on the sensor wires. Is that correct? How can I remove the tight boot over the actuator body?
Actuators are 18", 24", 36". Where is this measure taken?
Not sure how I would do this. I only have access to the bottom of the actuator where the wires enter for connection to the terminal strip. I believe I see the reed sensor covered in waterproofing material.
Heavy Duty C-Band Satellite Actuator
