Titanium Asc1
Kb Cool
1,452
3
Mesa, AZ
After many years of flawless use my Asc1 has bit the dust. It no longer appears to be able to communicate with my receiver. I originally thought my cable was bad going out to the lnb as i wasn't getting a signal any longer. So, after inspecting that and finding nothing wrong i decided to plug the lnb cable into my receiver bypassing the ASC1 and that did the trick. I now have a picture. So, from i gather is the ASC1 is not outputting 13/18 volts nor does it let the voltage coming from the receiver bypass to the lnb either. It also isn't accepting diseq commands. Anybody else experience this issue? I'm currently using the ASC1 manually as it still controls polarity and moves the dish just fine. You just have to do it manually.
Reactions: arlo
Titanium
AI6US
7,750
9,303
Meadow Vista, Northern California
The ASC1 does not pass voltage, the LNB DC voltage is provided by the ASC1 and the STB voltage is blocked.
I assume that you are using a feedhorn/LNB with servo motor?
1. Does the ASC1 respond to the STB DiSEqC move commands? and ... Does it respond to STB polarity changes (show polarity changes on the display)?
2. What is the ASC1 LNB Power menu setting selection?
3. What is the DC voltage measurement at the ASC1 LNB port?
4. Is the ASC1 AC Voltage selector (near the rear power plug) set to the correct voltage?
Kb Cool
1,452
3
Mesa, AZ
1. Does the ASC1 respond to the STB DiSEqC move commands? and ... Does it respond to STB polarity changes (show polarity changes on the display)? No move commands but i believe polarity was switching.
2. What is the ASC1 LNB Power menu setting selection? I tried all of them and nothing worked.
3. What is the DC voltage measurement at the ASC1 LNB port? Zero, if i'm measuring correctly. I put one lead on center electrode (hot) and other on the outside of the connector (ground).
4. Is the ASC1 AC Voltage selector (near the rear power plug) set to the correct voltage? Yes, its set on 115v
Kb Cool
1,452
3
Mesa, AZ
Sorry, we no longer offer repair services on the
Sorry, we no longer offer repair services on the ASC1.
Ok . well thank you for the quick replies. I really don't want to move on to a vbox and a LNBF but i may have to. Since nothing else is really available anymore. In the meantime i think i have directv lnb power inserter around here some where and i will give that a try. Since the asc1 is still switching polarity.
Kb Cool
1,452
3
Mesa, AZ
I hooked the power inserter to the lnb out of the asc1 and now it's working as far as polarity switching and i have a signal. But still no automated movement from the diseq 1.2 commands sent from the receiver. I have to use the front panel for east and west movement.
Do you have an idea which part needs replacing and would it be available at electronics supply house?
Titanium
AI6US
7,750
9,303
No magical component to fix...
As the issue affects both input DiSEqC sensing and output voltage, i would be suspect of the source of the medium voltage suppy. Could be as simple as reseating the ribbon connectos between tbe main and F-fitting PCB.
Place the ASC1 menu for fixed 13V or 18v output and start probing for dc voltage starting at the F-fitting PCB and work back towards the voltage regulator. Basic circuit flow troubleshooting.
Kb Cool
1,452
3
Mesa, AZ
Ok i'll have to open it up and take a look. Thank You
primestar31
15,194
18,522
Beta Omicron Delta III
I'd reseat any cables first, pull off connectors, then reseat them back again. Then look over carefully for any burned traces on the board, or burned/popped components. Then, look for bulged tops on electrolytic caps.
IF there's anything really blatant like that, replace them, or fix the traces, etc.
arlo Any input?
arlo
1,509
1,041
North Eastern
Yes I do primester! No LNB power. Things that make sense and just like Brian suggested.
Select either 13 or 18 volts and probe the LNB port at the rear.
I'm accepting that we have basic electronics skills and a lot of finesse. One slip and, well. You know.
A very good understanding of your mulitmeter and have a good set of cables and fine tipped probes.
I have a touch of reverse engineering on the ASC1. You're dealing with surface mount components but the voltage regulation and rectifications sections should be straight forward.
LNB Port. Voltage?
Backwards to the pcb connector. Be sure of the lnb power header pin and ground.
No power yet? Take good and clear photos starting now of connectors, etc. Sharpie marks for your reference.
Head to the low voltage LNB supply regulator IC. Get a datasheet if you're unfamiliar with it.
Got clean DC in? And out? Or is the problem further upstream and the rectifier bridge, filter capacitor?
(Mind you. This is general from memory and I don't have a board in front of me). But I could. Later.
A piece of paper and pencil to draw the circuit at the least. Start with the basics.
If I could catch Mr. Titanium in a good mood. I wonder. How many requests do you get for repairs?
I have a couple of these units here. I'm lacking just a little something to make two of them work.
I was wondering that since you (bummer) aren't offering repairs. If you wouldn't mind if I tinkered a bit.
At your suggestion. Kind of. I took a donor ASC1 board and pulled melf diodes and looked up datasheets from the smd marking codes of active components. I have a pretty good idea of what it takes to at least circuit trace and identify failed smd components. You know.....is that a zener, schottky, or small signal diode....pnp, npn?
What mcu pin is what and where do the via's go to......
Not to make a fortune. To keep them going. Okay, maybe a cold Sammy Adams Lager here and there.
I am in the same boat. If the ASC1 is a Zippo and a vbox is a Bic. Zippo is a 45 minute drive from me, As is Case and Ka-Bar. Oh. I have the Cyclone. I'd like to be able to try it out.
VictoriaFTA
223
242
Chicago
If you can't fix it then you'll have to give the Research Concepts controllers a try. They are the only alternative to the ASC1. I can attest that the V-box is ass. Don't waste your money on them. I don't know what cheap third world garbage those things are designed to drive, but I fried a V-box within minutes trying to drive my 12 foot dish with it 🙄
The annoying thing about the Research Concepts controllers is the unfriendly interfacing. Uses an obtuse serial port interface, so you'll have to get a USB adapter to control it. No DiSEqC support; you have to use their ancient software to change positions with a PC. And they charge an absurd $1,000 if you want to add a web server module to make interfacing with the controller less annoying. Clearly a price point that was designed to rip off a corporation, not for a home user.
There's definitely a market for a user friendly controller that can drive a decent dish without exploding. It's a shame that no more ASC1 units will be manufactured. All existing stock of it was sold out long ago and on the rare occasions that the ASC1 pops up on eBay I see it selling for several times its MSRP, indicating that there is still demand for them.
primestar31
15,194
18,522
Build a separately powered interface dual relay box with a more powerful transformer, say 6 amps 36 volts. It gets hooked to your dish motor, and the input to it is run by the V-Box. So the V-Box never sees a huge power drain, as ALL it controls is the relays in the interface box.
You can get these transformers out of old C-band receivers that have dish movers built in.
Reactions: Brct203 and FTA4PA
arlo
1,509
1,041
North Eastern
Actually if you contact dreambox 1959 on satellites.co.uk he might build you a better-than asc1. Not quite sure is it incorporates skew control for a polorotor.
RC controllers are robust and relatively cheap on eBay. Schematics and software are fully supported. I contacted them and asked if anyone had a diseqc interface. They have a lot of third party software developers. There are options for TLE satellite tracking if that's you desire and use an az-el mount.
But nobody I contacted was familiar with diseqc at all.
Then looking at the software reference manual and command string. Since there are Arduino diseqc projects. No hits on suggestions so far. A transcoder interface to receive and forward commands to the RC mover would do it.
Yes. An h bridge and external current limited power smps with would help a vbox live I would think.
More elegant and less parts would be one made from solid sate relays. Motor reverse polarity could be directly applied to the SSR inputs with current limiting resistors. Because the trigger side of SSR's is simply an LED.
You could do it Klipsch crossover style on a fancy piece of mahogany or oak. A Meanwell SMPS...you're golden.
Reactions: primestar31
C-Band Not Aligning
