Red-necked automatic Psip ATSC EPG grabber
primestar31
15,863
20,610
Beta Omicron Delta III
Until we get something built that's better, you can use the WebIF TIMERS screen for setting automatic daily timers for OTA channels.
I'd much prefer an automated web grabber to grab EPG from Tvguide/Zap2it/TitanTv, and I have a manual one, BUT, I can't figure out as of yet how to get the Mio to see the downloaded XML data file and integrate it into the OTA EPG guide. There's Rytec automated epg plugin's for NA SatDreamGr, but even if you install them, they refuse to show up in the Plugins screen in order to set them up. Though the folder and files appear in the /root/etc/enigma2/epgimport folder, I suspect something in the image is stopping it from working. IF I could get that to work, maybe we could change the http sources in the file to grab from where we want.
You can set "Just Play" (channel zap) timers for OTA channels to run every day for a few minutes. Say for each MAIN channel of a group. Just long enough to grab updated PSIP EPG data for the main and sub channels. Set them like 5 minutes apart, or however long you think it takes to grab EPG for that channel, and have them fire off in turn. Sort of a red-necked automated way to do it, but works until we figure out something better.
Go into the WebIF screen by typing your Mio's IP address into your browser. Then upper LEFT corner, hit the TIMERS link, it'll bring that function up in the middle. Then "Add Timer" click "Just Play" box give it a name, then use the drop down channel list to select the channel. Set your first start day and times, SAVE, click on 'REPEATED for each day you want this to happen, SAVE.
By the way, you can set recording timers for both satellite and OTA tuners at the same time. They'll both work fine. Also, even when recording, you can still LIVE watch (or record at the same time) any OTA sub-channels from that station, OR channels on the same satellite transponder. Channels not live watchable right then will be grayed out.
P.S. IF you do this on a particular slot image, I do NOT know what would happen IF you are booted on a different slots image when it's time for a timer to fire off. I haven't tried that as of yet. Will it work, or will it skip that day? I suspect it would SKIP/not fire.
I've got a bunch of "just play" timers now set for a time span between 3 and 5 AM every day. Excited to finally be able to use this STB as a true OTA DVR
Reactions: primestar31
I record nearly everything before I watch. That way I can skip the commercials using the SKIP buttons on the RCU. SOME commercials are interesting and watchable, but MOST are NOT (IMO).
I record new episodes of series programs I like; mostly on PBS. My daughter likes Sunday night Fox shows (Simpsons, Family Guy etc) so I record those for her.
It works! Genius!
What make or model dongle are you using ?
Did I miss something or did we lose support for the 955Q on the osmio4k?
Make sure you have this driver installed. Or whichever version is compatible with the version of TNAP you are now using. I have this driver in TNAP 4.2, but I stopped using the MIO for OTA, so no longer have the 955Q hooked up, so I can't check in TNAP 6: Best OTA Solution using Edision OS Mio+
I'm running TNAP5.0 and I don't see ANY driver listing.
Is it in the plugins you can download? If not, you'll have to ask El Bandido, as I don't know. I stopped using my Hauppauge tuner on my Mio a long time ago. Last image I used it on, was TNAP 4.2.
I use mine for satellite, and nothing else.
Is it in the plugins you can download? If not, you'll have to ask El Bandido, as I don't know. I stopped using my Hauppauge tuner on my Mio a long time ago. Last image I used it on, was 4.2.
I haven't been in that forum for a long time. I should mention to him that I can't get webif to work with the latest TNAP 6 build either.
TNAP images have the Hauppauge drivers pre installed.
Plug in the device then full reboot and you should see the little
lights on the Hauppauge light up showing it is powered.
Go to the tuner menu and it should be listed as tuner C in the Mio4k+
if it is the only usb device connected.
I am using TNAP6 osmio4kplus 20251112 image and webif is working fine here.
Check your network and make sure the IP address is correct.
It's not an address problem since I have assigned a static IP to the box. Anyway, turns out that webif works fine with http but not https. I activated https but the setting doesn't get saved in TNAP 6. https works fine on TNAP5 though.
The light is on but nothing gets scanned in. The cable and antenna looks OK though. The tuner menu shows a Tuner C but it's identified as an LG LGDT 3306A (enabled), ATSC terrestrial, instead of Hauppauge 955Q. Rebooting doesn't help. I wish I had an external spectrum analyzer that covers the TV band.
I scanned using the other osmio4k that the wife uses, it found 8 channels but I couldn't get them saved. Her box is using TNAP 5.1 and identifies the 955Q as the LG also.
Yeah the LG Electronics LGDT 3306A is normal. Seems there may be a problem in the image of TNAP 5 that is causing the no scan. I have had that problem in the past.I don't know how to fix it myself other than upgrading or downgrading the image. The Lastest TNAP 5.1 dated 2024-07-29 has that problem also so do not try that one.
Edision Login/Password TNAP6
Bouquet Editor for Edision
