You will find out you will be much happier with 2 separate dishes.
I would guess that the C/KU issue is more of an issue with the LNBF itself then the dish.
I started with a KU setup. When I got my 8' C band dish I tried to get KU on mine but found that when I was aligned well with a C band sat, KU would not come in. I had to bump a click or so east/west on my vbox to get a signal. Even so, the signals were not as strong as they should have been and because of this some KU transponders wouldn't scan in at all. While some have had good results this appears to be the problem most people experience with a dual C/KU setup on a big dish. After messing with it for a while I decided to go back to my separate motorized KU dish and installed a Titanium C1PLL on my 8' for dedicated C band. Been happy ever since!![]()
Just for curiosity sake, how many on here besides me successfully us a combo C/Ku LNBF with your BUD?
You may be pleased with your results sir, but you would be astounded by the improvement if you converted.
I figure eventually DMS will do another production run and make them available again some time in the future if the hobby itself doesn't "tank" before then.Quite the contrary as I REMOVED a Corotor II and installed a DMX741S years ago and saw little if any difference at all across the board, ie, A/B testing when I made that switch. I will agree with Scott though that using one probably does require a GOOD dish and more fine tuning.
I guess this is moot point now as those combo LNBFs are no longer produced but I just can't help saying something when this topic comes up especially when someone stands to gain from users having to switch to the Corotor type feed horn. The old saying of "follow the money" applies then.![]()
I've gotten several of the combo LNBFs from ppl on here that pulled them off so hopefully I've got enough to last me a while.I figure eventually DMS will do another production run and make them available again some time in the future if the hobby itself doesn't "tank" before then.
Scott, have been able to work on the 8" dish from Tek2000?Yes they want to send me one, but I will not be able to use it or put it up until the spring. Have almost 5 feet of snow here.![]()
