Amc9
gopher2
88
AMC9 i thought was my due south satellite
i am at 83.0, 42.5
according to lyngsat its still at 83.0W
but in a recent post it is mentioned to be at 85.0W !?
any ideas?
also is there still a full tile analog test card up there?
i only ask cuz its a pain in the butt to hook up the analog reciever
amc9 is still at 83
there is a test card (analog) at TP19
one to see maybe if working is 11775 H 4232
other option would be to use Nimiq2 (82) as the true south...you would need a DBS LNB for that (and to change LO frequency to 11250)
in all honesty..instead of trying the analog, I would use Nimiq2...its strong enough that 1 degree isnt going to make a difference :)
Is there any linear on Nimiq 2 ?
on lyngsat it looks likes it circular
OOPS you just said it
nevermind..
Is the test card still there? I looked last night and was not able to see it.
I found it. It may have moved since the last time I saw video on it?
Iceberg said:
amc9 is still at 83
there is a analog one up
but it seemes weeker than usual
I think i am having troubles with my motor mount/brackets
before i tighten the bolts i can lock onto some strong signals
as soon as i start tighting the bolts i the motor and dish move and i loose signal
should the square u bolt be pulling the bracket by the bracket holes on the side
or should it be touching only the verticle middle spline where the bracket touches the pole
Mine did the same... I actually peaked my azmuth with the U-bolts - lol.
Average signal streingth... On KU Birds
Comparison between a 0.5 and a 0.4 LNB
