Can you get Hispasat (30.0) with an 18" dish?
Really liked the solid block.
Thought about some paving stones one time... wanted to put my 5 gallon bucket of cement on one.
Found some 24"ers but couldn't get 'em into my car. :(
Never thought of screwing directly to one! That's brilliant.
The metal brackets are a spectacular find.
I'll have to go get a few of those.
Some of us'll have to try a few cheap LNBs on our Phase II and III dishes, with these brackets.
One nice thing on your side is that you didn't skimp on the LNB
That's a pretty good one you chose.
But, there's just one thing I have to complain about, z4ccamaro.
Who uses a name like that and then a train for an avatar? :eek:
Very nice! Ok, so now my question is: How do I figure out approximate settings for my location? The Satfinder program I have only does sats betw 60 and 160W, as far as I can tell...
Thank's for the comments guys.
I was going to try to make a NPRM from angle iron and put blocks on top of it, But for a quick and easy "temporary" setup, I just screwed the mount to a solid concrete block. I only had one blow over once, and that was like 90 mph winds !
It worked well enough for me so far, and I will probably be moving in a year or two so I don't want plant any more poles than necessary. I've already got a 10', a 6', and a Pstar concreted in.
I've got mine in the landscape rocks behind my house. Just make sure the block is solid and level both ways. Makes setup a lot easier.
I had scanned this sat with a 76cm dish first and it worked great.
Then I wanted to use the 76 for another sat, but didn't have another dish for Hispasat. So I got to thinking I'll try it on an 18 til I get another bigger dish for it. Works pretty good for me anyway. I had another linear LNB anyway, so didn't cost anything to try except the clamp/brackets.
If you can't get it on an 18 to start with, you might want to try to scan it in on a bigger dish just to get an idea of the direction and channels that are stong for you.
Hmm, this thread makes me want to try it with my spare dish 500 since I can't hit it with my motorized setup.
setting up dish for Hispasat
confused again
