Your right, sorta. A toroidal dish is only using part of the dish for a particular satellite location, but that is by design. I think someone here compared the performance of the T90 a while back and IIRR was slightly less than a 'normal' 90cm.
Multi LNBF's on a normal offset dish (and BUD's) use the whole dish, but in a less and less focused situation as the are displaced from the the focal point (the 'sweetest' sweet spot). So offset LNBF's would be more affected than the one at the focal point.
For an elliptical dish the best feed is the one that matches the dish. (That actually goes for all dishes) So yeah, the best would be an LNB and the 'funky' elliptical feed. You'll notice that Catamounts dual feed has longer waveguides (tubes) allowing them to be bent to fit 2 LNB's to get 4 degree separation. Post #47 Also note that the feeds are aimed at the center of the dish.
If considering dual satellite operation I'd think the dual starchoice LNB would be the way to go (4 degrees) post #47 & #50 (but I can't remember (the pictures of it) if your dish would accept it) (since Catamount is using one, maybe he's be willing to sell the one he's not using????) For the time being, I'd just get the single working and then 'go from there'. I've thought before results in the past and always seemed to slow progress.
) illuminates area of the dish equivalent to 1m simple offset dish?
