Corrotor II Plus ?
needs vs wants
The more info you give, the better the answer you will receive.
Where are you located, and what bird are you trying to receive, that you need circular?
I'm assuming you want circular C-band.
The Corotor II Plus info may suggest it'll do circular and linear, but there's no magic to it.
As far as I know, it's just a wide band model.
It comes with the dielectric plate you shove into it, for circular operation, just the same as the non-Plus version.
As for circular Ku-band, I've never seen anyone report that the dielectric plate would work for Ku (on that sort of feedhorn).
It may. But the the web site linked above pretty much says that circular is for C-only.
If you need circular AND linear on C-band, the best option is probably two dishes.
For Ku-band, there IS an LNB that does both, but it would not get C-band.
U are right iam looking to have Cband Linear and Circular in this case for NSS806 and CBand linear for regular birds in America.
I am not sure either I may need Ku Circular with this set up... I have a WaveFrontier with 8 lnbs for this case.
Subs
FX?
