DVBDREAM v1.4 released
The elecard codec worked for the 4:2:2. The machine I have is a little sluggish for HD so I'll have to upgrade, but now I know what will work and I have an idea of what is going on :)
version 1.4i , Feb 3rd 2008
What is new
v1.4i (03.02.2008)
  • Faster scan for NA satellites
  • Some TS record problems fixed
  • Improved Vista compatibility, Vista AERO window movement bug fixed
  • Ch. name text filtering option for general and favorites tabs
  • Fix for 19.2e DVB-S2 crash problem and network search (DVB-S2 TPs)
  • Now it is possible to override/correct the missing channel name or wrong crypted channel status with help of a text file. (scan_override.txt)
  • BDA interface update (v2.0)
  • BDA: Added support for Turbosight TBS 8920 DVB-S2, 8910 DVB-S and Compro VideoMate 500 DVB-S
  • Video and audio type indicators added, next to video/audio buffer bars
  • Now OSD Now/Next info should be always up-to-date
  • New HotKey to change (cycle) audio pid: 'A'
  • Guids.ini updated, some new h.264 entries added
  • EPG parser now supports DISH and BEV 9 day epg
  • Portuguese(br) language added
  • * For FTA sats, you should disable "NA fast scan"
  • * During fast scan, first TP will relatively take longer.
  • * It is important that NA users should enable "Customize for NA" (preferences->localization)
  • * You can utilize ENTER, ESC keys in channel name filter box
Thanks for the information anole...
Any guinea pigs out there that have tried this out...? Curious about any "gotchas" before I go and load this up. I'm assuming all my pre-programmed scheduling and sats will NOT be lost...?
:confused:
Superbowl XLII the feed or? G-16
The Fugitive Fans
