Just because you scrolled thru his channels, doesn't mean it's not on another dish.I saw the picture on tv and switched through the channels. there is no other sat dish on his property.
Later I sent a friend with a tele lens to take pics of his set up on his roof.
This is for real.
Have you tried what I suggested in your meter thread?
Sent from my SPH-L710 using Tapatalk 2
I meant on the akhi dish not your 8footer. I'm running out of ideas to help with this. You said you know someone with this set up working. Maybe ask them if you can take some close up pics of the lnbs and specifically splitters or switches. Make sure they're close ups.
Here is what I observed and photographed:
Non SWM lnbs for Ka band. The right Ka lnb 103W (seen from behind the dish) is combined with the Ku 101W and the 101W has an inline amp before it is combined and hits the switch. The other Ku lnb 99W goes straight into the 99/101 inlets of the switch.
Every LNB uses two cables to the switch.
Two exits from the switch go to 2 receivers HR24 SWM. One receiver has the power amplifier which comes with the 6x8 SWM switch.
Let me know your thoughts. Thanks !
View attachment 88138View attachment 88139View attachment 88140View attachment 88141View attachment 88142View attachment 88143View attachment 88144View attachment 88145View attachment 88146View attachment 88147View attachment 88148View attachment 88149
I will be using a HR22 (non SWM) with 6x8 Ka/Ku switch, non SWM.
Wow... not that I'm gonna call you a liar but I have some serious issues believing this would work properly. Without seeing the labels on the splitters and amps that are rusted out there's no way I can for sure copy its setup.
My theory is those are high amp diplexers combining the 101 and 103.
I have a theory... but it's not a solid one.. try to use 3 sl3 LNB's.. peak each one per satellite. Obtain two zinwell 4x4s and one 6x8. Run two inputs from the sl3 for the 99 along with two cables from the lnb for the 101 into one 4x4. I'll call this 4x4A. Next run two cables from the lnb for the 103 with the other two cables from the 101 into 4x4B. Then run two cables from 4x4A into the first two ports of the 6x8. Then another two cables from 4x4B into the second two ports of the 6x8. Run two lines from the outputs of the 6x8 to your dvr with bbcs attached.
No idea if this will work but I'm trying... hutch what ya think about this in theory...
ok. thanks !
pictures:
1.) one pic 1: which Lnb is for what satellite ? left to right: 103W, 101W and 99W. right ?
2.) on pic 2: The imputs are from left to right: 103W, 103W, 101+99W, 101+99W
My questions:
Why two cables per lnb to the switch?
Why does the 101W cables have the inline amplifier ?
Shouldn't the 101W be plugged into the 13V ?
For me with a HR22: wouldn't the non-SWM set-up be much easier ?
View attachment 88159View attachment 88160
Q: in the pic above
Which is the 103W lnb and the 103W lnb
wouldn't they be opposite to the actual satellites in the sky ?
If so, the 103W Lnb would be the left in the pic and the 99W Lnb would be to the right.
btw. thank you all for your educated info and guesses. Every little bit will help to get me started.
