gateway timed out
$660.00
Site is running rough this afternoon.Scott you working on it?
I just hope that I do not come to the site to find that it is down due to crashed disk array or something. Something appears to lock it up for a while, like it is recovering from an error.
If it was a disc issue it would be happening all the time.
It's something chewing on the database which is locking it up causing the error.
It always seems to happen when I am not In front of a computer when it happens, so I can never catch it to find out whats causing it. When the process is done the site returns to its normal speeds.
I wish I was better with MySQL so I could better track it down.
Posted Using The New SatelliteGuys App (Beta)
It is happening now...
And I am logged in and trying to figure out whats causing it. I am NOT going to stop it, so for a few minutes you may get a Gateway Timeout Error.
Don't know if this is related but the basic image uploader for PC does not work, the url option still works though. Images from a PC can be uploaded by using the attachment tab with the paper clip logo only.
I was having issues with this earlier also. Maybe Scott has fixed it now. At least I know it was not just me, or something I was doing wrong.
Not working for me. Just tried. I normally use the attachment uploader under the "Go Advanced" Tab, that works fine. May be something with IE 10 or Windows 7. I would try another browser on a different machine but I have to shut things down. Big storm about to hit here. Once it passes I will try.
Back up and running. Works fine on a Vista machine with Chrome. I didn't actually post the image, just went as far as the preview. Worked good. Must be something with IE 10 or Windows 7. I cleaned up all the files in the browser. Still doesn't work. Glad I can rule out a site issue. I will continue to use the advanced option. Sorry to bother you with this Scott. At least we now know. ;)
Thankfully the storm wasn't to bad for us.
I found the issue to be with the Standard Document Mode for IE 10. While still using IE 10 but using IE 9 Document Mode the basic uploader works fine. When I go back to the Standard Document Mode for IE 10 the basic loader does not respond. Capture.JPG Capture1.JPG
I hate to risk of it happening again because I am posting... I have not seen the gateway timeout in over a day now, was there something fixed?
Having trouble right now myself.
S~
Login Not Rememberd
Issues with New update for the iPhone & Android SatGuys App
