Houston Tracker III Plus
elcheca1
24
Dominican Republic
Hi, I have a little problem with my Tracker Locator, when I connect the engine and press the EAST / WEST buttons, it must turn left and right and it does not do anything, the Tracker turns on well but that little option I do not know how to solve it, if someone has passed this please comment please :sorrow:sorrow:sorrow:sorrow
Does the motor move with 12Vdc battery attached to M1/M2 wires?
If the motor moves with 12Vdc battery, place a continuity tester across the S1/S2 leads as the motor moves. Does the continuity meter show open/close cycles?
yes, I connect a 12v laptop battery and the actuator works, the problem is in the Tracker, I have not yet tried that of the continuity tester but you think that will help the tracker work?
The continuity tester will indicate if the reed switch is opening and closing as the actuator moves.
Well, my friend, I do not know much about that, that he will show me the continuity tester, what reaction he should throw when it comes to doing what you say he does
Norsat
Lubricating a HH Cband Ajak mount
