Invacom settings
c-spand
1,408
845
USA
I put up an invacon universal lnb picked up better signal but the frequency is off by 5? Using a Edison osmio . should i change settings.
Magic Static
7,498
4,853
Montana
If the L.O. is off then doing a blind scan will show all the transponder frequencies off by 5. Not a real problem. But if you input the transponder frequency manually you may not get it because of the shift in L.O. Because it's a Universal LNB your Hi-Lo band switch is 5 off also so it may cause an issue getting signal at the edge of the range of each band.
c-spand
1,408
845
USA
Thank you magic. I replaced the lense on this too. It might have something to do with it. Signal is really good.
Titanium
AI6US
7,707
9,212
Meadow Vista, Northern California
The lens is RF neutral. The Invacom's seem to have a tendency to drift off frequency with age. Have several QPH-031's that were 5MHz off several years ago and they are on a long list to check every few years to see how far off they will drift. :)
Tore one down many years ago and re-tuned the slug.
Reactions: c-spand
c-spand
1,408
845
USA
I just read an old article about that interesting. I guess i could take off the silicone and see what to adjust. I might buy a new one. Saw they still have the new ones with the circular and linear. It is really good lnb. I assume the news ones are same.
Just received a Channel Master 84E with dual LNB holder.
Question on the GEOSATpro 90cm Reflector
