LNBF
Nosbod
SatelliteGuys Guru
136
5
Blind River Ontario
I've visited quite a few web stores looking for a dual C\Ku band LNBF and haven't had any luck. I was wondering if anybody has come across anything like this.
If you're going to consider the DMX LNBF make sure you get the "S" model and not the "U" model as it has some funky LO settings on the Ku side instead of the standard 10750.
I have not seen a (DUAL) C/KU LNBF supporting two receivers. However I use a Dual Ortho Feed and 4x8 multiswitch, which is capable of multiple receivers. The DMX-741 and the dual ortho feed & switch setup use the same LOF settings in the receiver The only draw back is the extreme cost of a orthomode feed and LNBs.
V-Box woes
