newbie racking my brain
There are nets on the G10R satellite in English (KU band)
You would need at least a 6' dish for C-band. (And the LNB)
Your LNB is a Dual if it has two outputs!
My first install was also tough, I feel your pain!
I was tryting to get Sky Angel a few years ago.
I totally failed because of TREES. I found it on a ladder across the street from my house.
I was able to get it a few years (!) later when they took the trees down to put some houses in behind me.
I feel your pain! I'm glad things are starting to work for you now.
These guys know their stuff and will get you going if you persist and don't give up.
(I'm wrestling with getting good sat reception after installing my SG2100 motor...)
Pray for no rain here tonight.
keep hanging in there...
it will work eventually. It took me a while to figure out what the heck I was doing too... I was even at one point calling local installers, and getting nowhere. I think around that time Iceberg actually suggessted that I look on the right tp and bingo I had a signal no time flat.
good afternoon
ok dual lnb, is that dual meaning for two rcvrs, or two types of sats? should i have them hooked up with diseqc switch ?
also i have an old direct tv dish and rcvr that was left here by previous owner is their any thing that can be done with it? can i hook dish/lnb up with my system,and would it make any sense to?
lnb says BSS 12.2 - 12.7 GHz 950-1450 MHz TCE stock#23594
214-5100-700 lot#106
thanx again :)
