SYNCING TWO TV'S
raven316
79
19
Athens, GA
We're having a Super Bowl party and have tv's in two adjacent rooms.I'm running one off the Joey but there is a lag between the two signals and it drives us nuts. Is there a way too sync them?
There is no way to sync the Hopper and the Joey since the Hopper is getting the feed, then sending it to the Joey other than using an HDMI splitter
Syncing the Hopper recordings with Joeys would be a nice feature for DISH to add to the Hopper/Joey whole home system. There are several of us SatGuys that like watching the recordings synced to different rooms.
Ah, make sense. I wonder if using the dvr on the primary set and then pausing it till the rare the same would work?
That is your only real option, to pause whichever is ahead and try to sync.
There will be noticeable difference even with an HDMI splitter, due to the digital processing between input and speakers
Reactions: TheKrell
I have 3 tvs in different rooms all hooked up with an HDMI amplified splitter and I can hear no difference between the three sets. All are run thru an Onkyo AV receiver.
Can join the hopper 3 from a joey. It wont work with dvr events, but it will work with live tuners, can be delayed as well.
All the trick play works too.
Not sure its exact audio timing. If there is a tic of delay , guessing that there might be
Well I'm having another SB party, any changes this year as far as sync?
The solution lies in syncing the audio. Nobody's going to notice the video's not in sync.
Pick one room as the sole source of audio for both rooms. Send that audio to play in the 2nd room. The Joey and the Hopper, in addition to providing audio via HDMI, have a redundant audio output in the form of RCA L and R jacks. Does one of your two rooms have a home entertainment amp? Buy a long RCA male-to-male extension cable and run the audio from the Dish box in one room to an unused (e.g. Tape In) audio input on your amp.
I have a half dozen amps all over my house which pass audio tape-out to tape-in, amplify it and play it through speakers for the given area, and pass it on. Everything plays in sync.
why would someone leave dish
Dish Anywhere on PC - says offline, but it is not
