TheList
The calculator is VERY COOL:hatsoff::bow
I install FTA around Oregon and Washington - I always print out a chart of the Satellite Elevation, Magnetic Azimuth, and LNB Skew before I head out for the install. I will use this - a very handy tool indeed.
and Thanks again!
Bob
thanks for this feature. Any chance we could get Google Maps like Sadoun has, my location has excellent aerial photos. I just click the exact part of my house the where the dish will be and it draws the line of sight, I then have a very good idea of where exactly I should point it (Ex: the neighbor's basketball hoop).
Thanks, currently I haver not planned on adding that feature but I may eventually add it. I looked at the Google Maps API and it looks very simple to add. Until then if you want pointing maps I recommend you use our GOLD Sponsors pointing utility. (If enough people like that feature I can add it)
Why is it that the list only contains Hispasat 1D when in fact 1C also transmits to the American region?
The folling c/p was taken directly from the Hispasat website:
Hispasat 1C
The Hispasat 1C satellite is located at the 30º West orbital position. It has 24 transponders with the flexibility of operating flexibly in both up-links and down-links in both Europe and America.
Hispasat - Satellite fleet - Hispasat 1C
Hispasat - Satellite fleet - Hispasat 1C - Coverage
Please remove 12177 V 4500 SuperShow, Superland since they are no longer available on Hispasat. I confirmed that with no signal on my CS6K.
On the Lyngsat site it can also be confirmed that this beam is no longer available on Hispasat.
Week 11 080313 SuperShow and Superland left Hispasat 1C
Headlines - LyngSat
Thanks again Textin, I though I removed the 12177 V 4500 transponder but I guess I did not, so I removed it now.
When I added Hispasat to TheList the information I looked up showed that 1C was only broadcasting to Europe, the information that you provided shows that it does broadcast to US, so I added the 1C part to TheList.
Thank you very much for all your help, I greatly appreciate it.
Hispasat 30.0W updates 25 March 2008
11884 V 27500 (make changes only to the items listed here, all other data is correct)
item 3 Channel Name- Canal Educativo 1 (all other data is correct).
item 4 Channel Name- Canal Educative 2 (all other data is correct).
item 5 Channel Name- Cubavision Internacional (all other data is correct).
item 6 DELETE
item 15 Channel Name- Señal ACN (all other data is correct).
12053 V 27499 > should be 12052 v 27500 (all other data is correct).
12052 V 27500
item 110 Channel Name- ETB should be > Canal Vasco, (all other data is correct).
12143 V 3255 > should be 12142 v 3255 (all other data is correct).
12146 V 4200 > should be 12145 v 4200 (all other data is correct).
12157 V 2222 > should be 12156 v 2222
Channel name- Canal 6 COOP should be > Canal 6 TV Cooperativa (all other data is correct).
Add to list:
12159 v 2348
Channel Name- Canal Luz Satelital
SID- 1, VPID- 308, APID- 256, PCR- 308, Provider- TVE - America, Encryption- Free!
12165 v 3029 > should be 12162 v 3030
Channel Name- C11 Salta should be > Canal 11 Salta (all other data is correct).
12171 H 27500 > should be 12172 H 27500
Add to list:
Channel Name- 2M TV
SID- 11, VPID- 1101, APID- 1111, PCR- 1101, Provider- GlobeCast Spain, Encryption- Free!
item 14 Channel Name- Muslim TV should be > MTA International (all other data is correct).
item 17 Channel Name- ATP Bangkok should be > ATEI (all other data is correct).
item 19 Channel Name- C CANARIAS TV should be > TV Canarias Internacional (all other data is correct).
item 368 DELETE
Documented frequencies from Hispasat
the frequencies that are off by 1 is OK. Each LNB scans different :)
guess I'll have to rescan Hispasat
Most of the frequencies that I made corrections to are actually published on the technical document provided by Hispasat. Those not on the list I actually got using my CS6K.
See here:
http://www.hispasat.com/media//FlotaSatelites/Hispasat_1C/dossierHSA_1C.pdf
http://www.hispasat.com/media//FlotaSatelites/Nuevos/Hispasat 1C.pdf
Other documents available on Hispasat website:
Hispasat - Satellite fleet - Hispasat 1C - Downloads
Some C-Band updates recently
72 & 87 were recently scanned and added
55.5 & 58 Qwert scanned (I can't see those due to trees :( so not everything is up on there
Thanks for noticing! (You reminded me to add the "DISH Network Transponder Map" that I had added but forgot to link to :))
I like the idea about adding a Glorystar channel list, but I have to figure out what transponders contains the SDT and NIT for Glorystar (or if someone knows could you please share the information with me :D) .
Woohoo! We have an updated Glorystar channel list now. This should be sufficient for The List!, no?
Another idea:
How difficult would it be to hyperlink the Channel Name and Provider's web site (where available)?
Here's a stab at some addresses. I think most are correct... ;)
(GloryStar) VBS Radio
(GloryStar) American Liberty Radio
(GloryStar) Al Karma
(GloryStar) Daystar TV
(GloryStar) TBN Nejat
(GloryStar) Overcomer/Star4
(GloryStar) Telepace
(GloryStar) Rodnoy
(GloryStar) CNL Russian
(GloryStar) The Word Network
(GloryStar) Spirit 1 Radio
(GloryStar) Cancao Nova
(GloryStar) Cancao Nova Radio
(GloryStar) ABN
(GloryStar) Impact TV
(GloryStar) EzraWeb Radio
(GloryStar) Safe TV
(GloryStar) Cornerstone
(GloryStar) LoveWorld
(GloryStar) God's Learning Channel
(GloryStar) TBN Russia
(GloryStar) TBN Enlace
(GloryStar) Smile of a Child
(GloryStar) Emmanuel TV
(GloryStar) KNLB Radio
(GloryStar) JCTV
(GloryStar) 3ABN English
(GloryStar) 3ABN Latino
(GloryStar) 3ABN Radio
(GloryStar) Radio 74
(GloryStar) GCN TV
(GloryStar) Bethel TV
(GloryStar) Apostolic Oneness
(GloryStar) Gospel Music TV
(GloryStar) Miracle Channel
(GloryStar) Esperanza TV
(GloryStar) Hope Channel
(GloryStar) ATN/ACN Service 1
(GloryStar) ATN Service 2
(GloryStar) LifeTalk Radio
(GloryStar) LLBN TV
(GloryStar) TRWAM
(GloryStar) CGN TV
Thanks RedSavina and Wescopc.
RedSavina - Thank you for the links, recently I have been busy, but a few weeks ago I did some editing to a test version of TheList and I am going to add an easier way for others to help edit and add information to TheList, one of those feature I am planning on adding is the ability to add links :)
Glad to help. I'm kind of flying blind since I don't have my system yet, but I did a comparison of TheList! and the Glorystar channel update form 4/3/08. Here are the differences I found:
* VBS Radio and American Liberty Radio are listed at Frequency 11714; Glorystar has them at 11716.
* American Liberty Radio is listed at APID 3015 and PCR 3015; Glorystar has them at 3011 and 2001.
* Al Karma is listed at Frequency 11786 and Symbol 28126; Glorystar has them at 11789 and 28125.
* Daystar TV, TBN Nejat, and Overcomer are listed at Frequency 11835 and Symbol 20770; Glorystar has them at 11836 and 20765.
* Telepace is listed at Frequency 11872; Glorystar has it listed at 11874.
* Rodnoy, CNL Russian, The Word Network, and Spirit 1 Radio are listed at Frequency 11965; Glorystar has them at 11966.
* Cancao Nova and Cancao Radio Nova are listed at Frequency 11999; Glorystar has them at 11998.
* Impact TV, EzraWeb Radio, Safe TV, and Cornerstone TV are listed at Frequency 12114; Glorystar has them at 12115.
* TBN, God's Learning Channel, TBN Russia, TBN Enlace, Smile of a Child, Emmanuel TV, KNLB Radio, and JCTV are listed at Frequency 12175 and Symbol 2297; Glorystar has them at 23000. Also, Glorystar has KNLB Radio at PCR 8191.
* 3ABN English, 3ABN Latino, 3ABN Radio, and Radio 74 are listed at Frequency 11821; Glorystar has them at 11822.
* GCN TV, Bethel TV, Apostolic Oneness, Gospel Music TV, and The Miracle Channel are listed at Frequency 11856 and Symbol 28139; Glorystar has them at 11860 and 28138.
* TRWAM and CGN TV are listed at Frequency 12119; Glorystar has them at 12120. Also, Glorystar has CGN TV at VPID 1460, APID 1420, and PCR 1460.
Also, there are a couple of additions that need to be made to TheList for Glorystar:
1) Church Channel, Galaxy 25 Ku, 12177 V 23000, VPID 47, APID 48, PCR 47.
2) Spirit WOrd, Galaxy 25 Ku, 12115 V 22425, VPID 2562, APID 2563, PCR 2562.
3) Vision Heaven, Galaxy 25 Ku, 11716 V 2000, VPID 2004, APID 3004, PCR 204.
4) Bethel Radio, AMC 4 Ku, 11860 H 28138, APID 3131, PCR 3129.
5) Radio Nueva Vida, Galaxy 25 Ku, 11716 V 22000, APID 3015, PCR 3015.
