Transparent Menu – How it’s working for me
squicken
1,046
I still can only get transparent bar in 1080i. Cannot get it in 720p.
Sean Mota
19,039
1,739
New York City
This could be a reason why some are seeing it while others do not. Anybody seen it using Native Rez? If so what was the rez of the channel you were watching when you saw it?
rudolpht
587
squicken said:
I just switched my STB from outputting 720p to 1080i. I can get transparent to work in 1080i, but not in 720p. Would someone else try this to see if they're getting similar results? When I switched back to 720p, no more transparent surf bar.
I cannot get it at 720p either.
Tim
squicken
1,046
Can't get it to work in native. The only way I can get it is in 1080i. Weird.
:confused:
barth2k
592
Am I the only one who DISLIKES the transparent surf bar? It just makes it harder to read. When I bring up the surf bar, I want to SEE the surf bar. I'm not trying to see what's behind it. Since it's at the bottom of the screen anyway, there's little info a non-transparent surf bar is covering up (usually). Soi while it may LOOK cool, it's counter productive IMO. I hope it's can be turned off (when they finally get it working).
dmm
Mar 31, 2004
19
When I wasn't able to get the transparent menu to appear earlier it was on an SD station with STB set to native mode. It does work, however, when on any 1080i channel. It does not work on ABC (720p), but it does work on ESPN. I guess this means that ESPN is still being sent at 1080i.
Sean Mota
19,039
1,739
New York City
You know that the transparent bar can be turned off by simply hitting the VOOM button or menu or fav...
