Two Hopper 3 Install is Scheduled
monroef
255
100
Thanks for your post monroef. I called the DISH President office and told her yours and my install issues and she credited my account $100.00 because I had to purchase the second Hopper 3 from DISH. The technician was not allowed to swap out the dishdepot.com Hopper 3. Thanks again.
Strange. Dish swapped mine out at their suggestion. I didn't even ask (yet).
charlesrshell
SatelliteGuys Crazy
11,297
6,044
O'Fallon, IL
I had no luck. The DISH installer's supervisor in St Louis had no luck. So the DISH installer called some special CSR he is allowed to call and had no luck. I even talked to the same CSR and he said he tried with his higher ups and had no luck. I am glad you didn't have to go thru all that. The DISH installer and myself spent a couple of hours during the install trying to sort all this mess out. Thanks to your info that you posted I was able to get a $100.00 credit on my DISH account. Thanks again.
charlesrshell
SatelliteGuys Crazy
11,297
6,044
O'Fallon, IL
One hybrid LNB can support one H3. That is why you needed two dishes to support two H3s. Now, with the 42 switch you can support two H3s on one dish...
The power inserter on the switch makes the difference.
Based in this wiring diagram on page 3 is how I installed two HWSs to a Duo Hub then to a DPH42 switch and then to a 1000+ DPP LNB dish and they worked great. On page 3 in the diagram there is no switch or power inserter. The two HWSs and Duo Hub are attached direct to Hybrid LNBs. I still kinda think we will not know if two Hopper 3s will work with a Duo Hub and no DPH42 switch till someone tries it out. I had thought the power inserter was needed to work DPP LNBs. I am not a satellite installer so I am just pulling things out of my a--. I may be all wrong. What do you think?
Bobby
Publican
73,092
30,489
Rohnert Park, CA
You should have a power inserter going to the 42 switch. I have my power inserter located near my hub but I am told it can just as easily be installed at a Hopper location. Remember, you don't have hybrid LNBs, the 42 switch is the hybrid piece that makes your 1000+ work fine.
charlesrshell
SatelliteGuys Crazy
11,297
6,044
O'Fallon, IL
I understand that Bobby. I do have a power inserter. Did you look at the diagram on page 3? Do you think two Hopper 3s would work if installed like the diagram?
Bobby
Publican
73,092
30,489
Rohnert Park, CA
If you read the criteria on page 3 it specific to working just fine with Hopper 1 & 2 and says not 3. Remember, H1& H2 only have 3 satellite tuners while 3 has 16. The power from the Hopper 3 alone can't support more than 16 tuners. I'm sure there are some more electronics in the 42 switch that allows 32 tuners as well as the hybrid configuration.
Almighty1
1,525
1,432
San Francisco, California USA
Hit options on your remote, then picture in picture feature, then select the 4 screen multi view, it will bring up 4 screens, then select any one of those screens by using the toggle button with arrows on your remote, and it will bring you to one of the screens , select one and if you use your remote in tv mode or use your tv remote control , hit information and it should show the screen at 2160p. It will stay that way till you either put the receiver in stand by mode or you turn off the multi view feature yourself.
Thanks, as soon as I chose the 4 screen multi view, my LG 65" 65EF9500 OLED lost the signal, I had to turn off and on the tv before it worked. Otherwise, works great and thanks for the instructions!
Reactions: MikeD-C05
charlesrshell
SatelliteGuys Crazy
11,297
6,044
O'Fallon, IL
stardust3, my 12 port splitter goes to 13 TV locations. However, at the present time I only have 10 active TVs. With my RF modulators, each TV can watch either of my two Hopper 3s.
Reactions: stardust3
charlesrshell
SatelliteGuys Crazy
11,297
6,044
O'Fallon, IL
That is a an old diagram and DISH had a one Hopper 3 limit. So of course the diagram would not show two Hopper 3s. But, you could very well be correct with your statement. The only way to know for sure is for some one to try out the Duo Hub. From everything I have heard, DISH also says that you have to use two Solo Hubs for a two Hopper 3 install. Well, I am using a Duo Hub and my system is working great. Now sometime if one of my Hopper 3s catches on fire or goes ape sh--, I will switch back to two Solo Hubs. :biggrin
JSheridan
8,899
10,030
USA
Charles, it won't work. A Hopper 3 all by itself won't even work on port 2 of a hybrid LNB, it has to be in port 1 to work. There's no way 2 Hopper 3's will work using 1 hybrid LNB no matter what kind of hubs you use. That's one of the main reasons the DPH42 was developed.
charlesrshell
SatelliteGuys Crazy
11,297
6,044
O'Fallon, IL
OK, thanks JSheridan for the info.
charlesrshell
SatelliteGuys Crazy
11,297
6,044
O'Fallon, IL
One more thing Charles. Using 2 solo hubs is preferred so the Hoppers can be easily isolated to not share or unified to share recordings, depending on what the customer wants. With a duo hub the Hoppers can't be easily isolated.
I think you can install more Joeys too if needed with two Solo Hubs.
kwindrem
646
130
I wonder if any one has tried running two Hopper 3s from a Duo Hub, no DPH42 switch?
No way. All the nodes do is extract the MOCA signal so it can be routed to Joeys. The duo node is really two solo nodes in the same box with common MOCA ports.
The hybrid LNB is responsible for selecting 16 transponders from 3 or 4 satellites to send to ONE Hopper. The DPH42 has circuitry for two selections so it's the only way to feed a second Hopper.
The power inserter simply provides enough power to run the DPH42 switch and up to 4 separate LNBs. All the magic happens in the switch.
SandFarmer
1,561
848
The Beach.
I have not figured out what you could use 16 tuners for, let alone 32.?
For us it's not 32 tuners, it's two individual boxes. From the minute we got service (1995) it's been the DISH culture of 1 box per TV with timers and recordings in one place per TV. For my family I installed a modulator that allowed us to have 1 box (3) per person (6) that they could watch on any TV (11) in the house. The early boxes had built in modulators that added to my system.
Now the axiom changed to everything in one place. I have tried to get them to share, but mixing timers and recordings (folders) all in one place doesn't work. Especially with the limitation of the number of timers and disk storage space. Personally, I keep a timer that I watch until that show ends. That can add up.
22 years of doing things in a particular way tends to stick. Two H3's will work just fine. Perfectly.
joekawasaki
167
19
Minnesota
Any one know what the monthy fees are for 2 hopper 3's on one account? I am aware of the $15 DVR fee. Is there also a receiver fee? I currently have 2 hopper 1s and pay $12 receiver fee plus $12 DVR.
Audio and Video Intermittently Out of Sync
H371 update problem recording live event Golf
