VIP722 SW Release L685
It would be 6/5/4 rows if the banner ad at the bottom of the guide remained turned on. I think that's what they meant.
so what you're really saying ;) is that the programers were lazy ... and didn't have the on screen "line" options updated based on whether the banner setting in that menu was on or off ... ie. if off it should have shown 7/5/4 as the number of lines options, and if on it should have shown 6/4/3 ... they just took the easy way and ignored on/off setting of the banner .. :)
After the update to my 722, I've seen some strange behavior with the new guide that I haven't seen mentioned. With the 6 (really 7) line setting, I only see a portion of the last line. When I page forward, the guide advances by 7, so I have to step back one if I want to see that last line. (Hope that makes sense). Not a killer, but annoying. It's possible it's my TV (an old 1080i tube set), but the other guide settings look fine.
PS. Give us back the option to turn off the live video window!!
That is your TV overscanning. It is not the receiver that is causing that.
I don't think so. If it was over scanning you'd be loosing the bottom part of every broadcast and most probably not seeing logos. I'm seeing the same thing. Missing line 7.
Edit of above. I was looking at my TV2 output when I made the above comment. On my TV1 output I'm seeing the full seven lines and am missing a little bit of line 7 on TV2.
Also, what is the most current software for the 211 and when was it spooled out.
My SD tv2 is missing the bottom line, my tv1 HD is fine. Minor inconvenience, but I switched back to the 5 line and sol good.
You should have found your search history is erased. I use this to search for 20 or more titles on 2 DVRs, in hopes of finding them someday.
They buried the HDD access. Now you have to do DVR + 6 to get to off-screen Media selection (5 displayed), then External/Photo, then read or write. (You can scroll down on the DVR list, especially if you notice the half filled triangle at the bottom of the list.) At least, a disk startup does put you on the review disk or save to disk screen.
-Ken
Thinking about getting Dish TV
1000.4 west arc pointing problems- 119 received on 129
