Virgin Island at 99W
carlospr43
967
12
US
Gal 16 99W
3845 h 15028
NBC (Ch-4) changed to H.264 AC3 1080i and doing some test. Right now the channel is black sceen on previous SID 4. There is a SID 3 V769 A770 (H2.64 AC3) but its Hidden. Most be enter (pids) manually
Enjoy!!:)
So for dummies like me who don't understand all the tech talk.........gone forever????
Which box do you have??? Its a High Definition??? If is HD then you should be able to get it. Once you let me know your model I can help you with the process to enter them manually
On the S9 the old CH 4 is a black screen using the 1025V 1026A PCR 1025 I put in the H264 for video type. The other channel did come in thanks. It is NBC my mistake, again:) Can anyone suggest which FW is the best with audio issues? I have C2HS2-11-12-B:0481CMT on the S9 now.
ironically Dish uplinked the ABC & NBC (in HD) now for Puerto Rico subs (not available yet)
CBS is from that "lovely" :rolleyes: WSEE in Erie
No fox yet in HD...but maybe soon?
Oh and before someone says it...no the uplinking of these in HD will not affect us seeing them right now. Dish has had them in SD for a while now (using the same feed as we get) ;)
Bummer , That's the channrl I use for sunday night football in my bedroom . There is another NBC ch on 99w , I think the same tp , (kcwy 13) . It don't come in on my mini-bud all the time tho , like the PR mux & leasa ch's. Guess it's time to upgrade . Thanks for the info .
Thanks for the info.
Carlospr43;
Thanks for the info. The PR Mux is important for me, although I get my ABC on the ABC NET-2 feed also. It will be nice to have another source for NBC in HD.
Just noticed the WVGN change. I input the pid info 769/770/769 and I get nothing using the Ali editor with the Micro HD...all the others are ok...back to the drawing board
You will need to specify that its H.264 and AC3 audio. Openbox editor has this option. I opened the Micro editor and couldnt found the option. Maybe the mediabox may have it. Maybe Brian or Ice can let you know
Channel is there and working fine. Manual entry is required
Yeh I get the PR Mux with my my homemade 38" wide X 39"tall dish , do loose it for short times , every once in all while , but that is'nt often . Never loose Lesea ch's off 99w tho . And thanks all for the info , especially Carlos & Iceberg !Picture 361.jpg
I was just wondering if anyone with a minibud is picking it up or it is now a lost channel.
LNB adjustment.
GEOSATpro 90cm Dish needs what HH Motor
