Hello
i tried two combination up to now.
The first one. the receiver connected to an ecoda 22khz switch. On port 0 my HH-120 motor controlled using usals. This worked perfectly.
On port 22khz an 8 ports diseqc switch, controlled using diseqc 1.2. Again works flawlessly.
Second setup, I decided to use my new V-Box II connecte on port 0 controlled with diseqc 1.2. Again working great and port 22khz still with the diseqc 8 ports switch. Again another win but not perfect.
The problem with the second setup is that I use diseqc 1.2 for the 8 port diseqc switch and the v-box. Since the ecoda switch bleed the commands on the two ports, the v-box wants to change even when I use the diseqc switch.
And finally, I don't want to hijack the thread (I will create another) but a bud with a v-box and a DVB receiver is great. Too bad I can't watch 4:2:2 feeds but lots of channels...
Labgate
