The birdog is not the problem, that is a nice piece of equipment , specially the last version 4 (USB Plus). Yours does not even say USB therefore it is version 2.5 but still a nice machine. Version 3 says USB
Dee_Ann . I would suggest you to update the SAT list of the Birdog first and foremost. Go to www.birdog.tv and using the provided USB cable or a similar one for that matter download the latest file for the different SATS up there. Click on News and Downloads , then click on Configure then read, it explais how to do it , it is easy. Basically at the bottom you will see a list of SATS to the left then Highlight every SAT you want on your Birdog (yours might handle only 32 SATS) and click on the double > sign . Once you have reached the 32 Sats limit or less if you prefer then click on Generate and it will ask you to save a .exe file . save it and then run that file and follow instructions.
All that will make sure the Birdog has the proper info for that SAT 129W for the TP for WhiteSpring. Maybe yours already has it but to be safe you should update it. Also when selecting the SATS make sure you select both polarities , for linear SATS it starts with KH or KV for Horiz and Vertical. Circular birds it starts as BR or BL for Right or left polarity.
Keep in mind that White Springs uses a very low Symbol Rate and for SR lower than 4000 it is recommended to move the dish slowly and wait kind of like when using the Receiver as a signal meter but not that slow !! otherwise the Birdog will not find it.
the birdog uses DDSI technology that basically reads the USID data stream coming from the Satellite and helps him identify it. Internet sometimes is a powerfull resource but in this case I am unable to find anything related to how this technology really works. I know the Sats emit also a beacon but have no idea whether it is the same or not...... Finally and now it all makes sense to me (the other day , well the post would be too long, lol). Forget the before mentioned technologies. The Birdog acctually searches for a particular carrier that it has on its list for every bird. That is why it is so important from time to time to update the Sat list as DVB-S carriers on Birds could change their parameters and also make sure you load both polarities. So basically on Galaxy 27 when the KH Galaxy 27 129W is selected it will probably search for the Starband or White Spring Horizontal Carriers , probably the highest powered for every bird. The birdog has like any other receiver a QPSK tuner only and therefore will not identify DigiCipher , or 8PSK or Analog or any other signals. Verion 4 that says USB Plus allows you to create a Custom Carrier and will also control a DiseqC and a 22 Khz Switch. nice piece of equipment , my hats goes off for the British for this one , well I do not even have a hat but you get my point lol.
Thank you! This is some very helpful information.
The man I bought it from showed me how to download new files and install them on it. It is a version 2.5 My neighbor made a programming cable for me for free because the man I bought it from (his friend) lost his cable for it.
It does already have several entries in it for the 129 satellite,
it has the following
BR Dishnet 129
UH Galaxy-27 129
KV Galaxy-27 129
KH Galaxy-27 129
KV G-27 Starband
I have tried all of them to no avail.
I sent an email to the birdog company to ask them for advice on finding the White Springs satellite. Hopefully they can tell me some secret trick or tip that will help.
Thank you!
