I did all that already when you posted it before.
When you say net, do you mean network or internet? Mine are not connected to the internet.
Needs to be hooked up to the internet to get MRV to work.
Sorry when I say net I mean internet. Are you using the Broadband DECA??![]()
I don't have anything hooked to my home network. The tech told me it wasn't necessary to get the MRV to work.
Simply put. To get Whole Home DVR to work you do not need to have it connected to the internet. The DECA system allows each receiver to communicate with each other. However, if you want to have On Demand then a DECA module is needed to connect the system to the internet.I don't have anything hooked to my home network. The tech told me it wasn't necessary to get the MRV to work.
Ok, I finally got another tech, one that knows what he is doing, to come to the house yesterday and fix my problems. First off the previous tech used a 4 way splitter instead of an 8 way splitter. I have 4 DVR's so I needed the 8 way splitter, which was causing picture freezing and not all DVR's were seeing all of each other's playlists. Also my HR20-100 did not have the splitter on it nor the filter needed to get enough power to power up the DECA unit and that was why it wasn't working, even though I told the previous tech and even showed him a diagram of it. So now everything is working great.
That's good. Did he hook up the internet for you?
No, they said it wasn't part of the workorder and it would cost something like $150 to do it. :rant:
If $150, means $25, then yeah it's $150.
Broadband Deca, i.e Internet Connectivity Kit, is a $25 charge, you can't just plug an ethernet cable into the back of your hr-24 and get OnDemand.
Can't you just plug a Ethernet cable into the white box with the green lights and it spreads to the other receivers?
you need a coax cable from your swm splitter to a deca unit. Deca unit needs to be powered. and the ethernet cable from the deca needs to be plugged into your router.
<deca power supply.![]()
Yeah I have one of those on my 24
