Should work fine ... i can't see the numbers on it, but its a SWM so you should be good.View attachment 126613
Will this one work?
Will this one work?
That's a swm type 3lnb. It will work great.View attachment 126613
Will this one work?
Let me see if I understand - I have a H24 receiver I'm taking from home. It's with a Genie & mini Genie. The set up shows on "switch type" SWM LNB 8 CH when in the house.
I have a RV set up with Slimline 3LNB SL3KNR0-02. When I tried hooking up in the RV I got a "cannot detect SWM" message.
Do I need to get a SWM box to connect through if I move my receiver from home to RV and back?
You're right about the "4" missing.
OK, thanks. I guess I'll have to get the BBC to connect then.
reboot means to turn off and restart the receiver, I assume.
 to Satelliteguys walimike!...
You'll have to reconfigure the set up each time you move it from the house to the RV and back ....You're right about the "4" missing.
If you do get a new lnb, you can get a non swm type, then you won't need the power inserter. You run the cable from the lnb to the receiver.
A note - I gave up on the "SL3K4NR0-02" lnb. I got a BBC but the receiver wouldn't change switch type. I couldn't get it change, it always went back to swm.
So I just changed lnb's.
You may be pointing at the wrong satellite. Can you post the signal strengths for 101?
