Do you have any experience putting ends on cables? If not search for a You Tube for installing COMPRESSION FITTINGSYeah boba
I saved money by not buying that winegard 200 preamp and for at most - 1 or 2 more channels
Was not worth the 37 dollars
Amazon charged. But I made one
Major screw up,I miss calculated
The rg6 coax I would need I thought
That 30 feet was enough relooking
Now I see I was off I should have bought 100 ft instead to play it safe
You will need cable clamps to anchor the cable to your siding about every 12-18". What is your siding made of Masonite or concrete?
Is the house prewired for cable or are you starting from scratch?
You should mount as high up on the chimney as possible and not over the vent, you don't want to melt plastic connectors or jacket on cable.
How are you doing on the original 5min. install from You Tube? LOL
any time soon
