TNAP would not install . I extracted all the files onto thumb drive, inserted into STB and did multiboot, held OK key down but does not take
Multiboot isn't the proper one, IF you can't get to the receivers slot menu to boot from. You need the USB version.
1. Unzip the folder osmio4k onto an empty FAT formatted USB thumb drive.
2. Open the folder and change the filename on one file from "noforce" to "force".
3. Remove the power cord from the OS mio 4K.
4. Insert the USB thumb drive into the OS mio 4K.
5. Attach the power cord and the TNAP image will be automatically installed as the main operating system (position 1 in multiboot).
6. When the OS mio 4K reboots, immediately unplug the USB from the STB. (Please note that if this thumbdrive is plugged into the STB with the osmio4k folder containing the file name "force", the image will automatically be installed when the STB is powered on!).
7. The OS mio 4K is now operating with TNAP image. You may now configure the settings and scan.
