OTHER GTMEDIA V7 or V9?
Lone Gunman
3,244
886
southeast
I'm thinking about buying one of these while they're still cheap and available. Anyone have any experience with either and which one would be best/easiest to learn to use for this soon to be 79 year old "old fart"?
HAPPY 4TH OF JULY TO ALL!!!!!
Just say'in
Reactions: FTA4PA
I have the GT Media V7S5X. Its blind scan works very well. It's easy to use. There is an editor available so you can do editing on your PC and then upload the database via USB memory stick similar to how the GSP microHD worked. I leave the USB memory stick installed on the receiver so I can always have a current database backup on the stick in case anything happens to the receiver.
There is no way to use a web browser on your PC to access this box. The Edision can do this so you can remotely view on your PC any channel received on the satellite receiver. Therefore you can't use PotPlayer or VLC to view on your PC channels using modulations not supported by the box. For example, I can stream 4.2.2. channels via the web interface on the Edision to my PC for viewing.
The youtube streaming capability is not very good. So I don't use it. I had to manually program North American satellites since it comes loaded with the European satellites. Often when I blind scan it wipes out custom names I entered for channels.
So the Edision is better in most ways. However, overall, the V7S5X is a great little box for the $30 delivered that I paid. I'm glad I bought it. I have no experience with the V9 model.
Reactions: Lone Gunman
One thing I noticed about the V9 is it supports HEVC, whatever that is and it's not mentioned on the V7? Is that important?
That and the V9 is a couple of bucks cheaper, not that the $2 would make that much of a difference.
Just say'in
The V7S5X can receive the HEVC transponder on 117W Ku which confirms it can handle H.265 / HEVC. This is a newer standard than H.264 / AVC. Also, V7S5X has interfaces for wifi, 3G and Mobile Tethering. I have only tested the wifi interface and it works fine for connecting via your home wifi to the Internet. For those with more networking savvy than I, this may mean you can communicate to the V7S5X from other devices on your home network.
How about firmware updates for the V7S5X? From what I read there were some problems with the V9 firmware a while back?
Modern receivers that don't support a web interface usually have at least one of two things, a DLNA server and/or support for a proprietary app called Big2Small. I believe someone here sniffed their network and wrote their own Windows program to access the latter capability.
Something I just discovered (duh!) after owning my GT Media V7S5X for more than half a year is that it can be programmed to blind scan a series of satellites automatically. My Edision cannot do this.
You simply select the satellites of interest prior to starting the blind scan function. I have always previously just scanned a single satellite at a time. It turns the motor appropriately between each satellite scan. I can now go prepare my coffee while my receiver works for me.
Been awhile since I owned one, but I think I recall the Edision having a background blind scan function
Edision can scan all transponders that it has registered. But I asked el bandido about an auto blind scan not too long ago and he said there were a bunch of considerations necessary (time to wait to move to next satellite was one) and it was more complicated than it might seem. Just now checking the menu structure of the Edision, I don't see any way to do multi-satellite blind scans. I'd be happy to hear if anybody knows how.
el bandido's discussion of this is here.
Reactions: comfortably_numb
I only have the V9 and am relatively new to FTA but its great. Thoroughly impressed for the money, it's interface is WAAY better than a similarly priced OTA DVR I have (although it does work). It's easy to edit the user database to add audio channels that don't "scan in". I don't have anything to compare to personally but it's been a breeze to setup and scan in satellites.
I bought a GTCombo (same people) a few years ago because they claimed it could do 4.2.2 video….it can't. And the other issue is that I have found the Android operating system to be very unstable. Quite often when changing the audio pid's the audio won't resolve either. You get what you pay for.
My Enigma2 boxes I can go for days or weeks without having to reboot. Better to spend just a few more dollars and get boxes with more capability. These cheap Chinese boxes they just want to get them out the door with little or no support but the E2 community is constantly tweaking and updating.
Reactions: byron and FTA4PA
Edision Edision Mio+ TNAP 5.1 w/Hauppauge 950Q
AMIKO Amiko MINI 4K UHD S2X - V1.0.69 Firmware
