Adjacent satellite interference is the exact problem, but it is unlikely that any change will occur on the G19 -11842 transponder due to the number of viewers that have been reaimed and reprogrammed. Unlikely that any of the relocated services would return to 101w due to the contained footprint of SES1.
The satellite operators have had discussions regarding the interference without resolution. We expect that this is the way that it will remain.
If that's the case then the only way to solve this issue with the current technical parameters is to start issuing larger dishes and/or stop issuing dual LNBF systems. With my experience as an installer, the only way to get strong signal on the current Azure 36 inch dish due to this interference issue is to only use 1 LNBF with the dish directly aimed to Galaxy 19 to avoid the signal loss associated with having offset LNBF's. If there is still a need to have a dual LNBF system, I recommend that a 39 inch dish be used instead of 36 inch as a larger and/or deeper dish will have a narrower acceptance of satellite signals which means that interference from adjacent satellites is minimized. Another option is to have a motorized dish system instead of a fixed dual LNBF system.
P.S. Can we get confirmation from Glorystar if there's any plans to to use SES-1 in the future or should we be converting all dual LNBF systems to single LNBF to improve signal levels with the current Azure 36 inch dish.
