CharredPC said:Well, that's annoying!
Hit a glitch on RTN Watching "Quincy."
it looks like a great episode, something about an epidemic, but right on the first commercial break, every time (happened twice so far) it just starts replaying from the beginning instead of continuing through the program. So now we're watching the first 10 minutes or so for the 3rd time, and chances are we'll never know what happens next!
lol.. sorry, just had to post about it SOMEwhere...
Gas said:1. The TUbe is same strength as all feeds if you have issues check cross pole
Gary
CharredPC said:It's been well-established that you know you've got a decent dish setup if you can get the Tube without breakupThat whole TP is quite low in signal. Whatever it's due to, it's been that way forever, and no peaking or alignment makes it as strong as the others.
no offense taken but I want to help you get the tp with good reception. Are you using an lnb or lnbf ?CharredPC said:Ok, then it's "crosspole."
YOU call it what you like, but, no offense, on receivers everywhere The Tube TP registers much lower than the rest. I won't pretend to know how the actual output power differs from the other TP's; I'm sure you're in the position to know best about it. All I was attempting to point out is that if you look through the history and old posts here on the website, it will show that we've always struggled with that TP, becuase it appears to be quite weak. It's always appeared that way, and (from what you've said) unless the neighboring sat's signals stop, it'll always be that way![]()
Again, no offence. We all LOVE the Tube, which is the only reason it was brought up![]()
Gas said:no offense taken but I want to help you get the tp with good reception. Are you using an lnb or lnbf ?
You aren't dealing with a bunch of idiots, we are all pretty hardcore into this and spend hours tweaking and optimizing our setups.MikeI said:You people are nuts. You are lucky enough to get a person (supposedly) that works at Equity to post here and then you tell him he's crazy and doesn't know what he's talking about.
