LET'S TALK ABOUT SWITCHES
techristian
11
6
Windsor
Ever since I have had an S2 switch and 2 dishes I thought the rule was the same for 4 way/ 8 way switches. C band sats TURN OFF 22K, KU band turn on 22k (in settings) but according to some sources that isn't true. 22k should be turned to AUTO for 4/8 way ACCORDING TO SOME SOURCES. Even though I got most of the bugs out, some funky things are happening. I'm not getting all of the channels. I DON'T HAVE AN AUTO setting for my 22k tone. I have been doing this more than 15 years and so I'm baffled.
My AMIKO doesn't have a auto setting for 22k. Sometimes it lights up BLUE and sometimes it doesn't.
Dan
The only time the AMIKO lights up blue (22k off) is when you have setup a universal LNB. Only if you have a 0/22KHz switch between your LNB and your 4 or 8 port DiSEqC, and have another LNB on the other side of your 0/22KHz switch, do you need to set the LNB to 22k on or off. (There is the one exception, if you set up a universal to only scan one section of the bands it can scan).
Otherwise, there is no point in turning on the 22k when using a 4 or 8 point DiSEqC switch, in fact, it just add extra unnecessary commands to selecting ports.
techristian
To add:
General rule: the settings for the switching signals by your receiver should match the needed signal for the switch(es), and the needed signal for the LNB.
Your "some sources" will probably follow that rule, matching the exact setup they serve; which maybe does not match your setup at all.
Your opening post does not describe your own setup in any detail. Without detail, we can only guess and maybe make wrong assumptions about what is needed and/or possible.
So for more detailed advice, I guess more info would be needed about the LNBs in your setup, and the types of switches: tone switches, voltage switches, multiswitches, diseqc switches (level x.0, x.1, x.2, or maybe multiprotocol).
Greetz,
A33
Can anyone guess what the real problem was?
Users Who Are Viewing This Thread (Total: 5, Members: 1, Guests: 4)
