Out on a limb
With the DREAMFOX dish and LNBF setup you get the perfect storm. This dish and focal distances come into play here. The wavelengths for KU and C Band on this dish create an interesting result. The C-band signals are exactly 90 degrees phase shifted.
so with his Panorama LNBF set at zero skew he is actually 90 degrees skewed to the true C-Band signal on this 1 Meter dish. If he rotated the LNBF 90 degrees he would have normal V and H in his receiver.
It is likely that you would have to use this exact same dish and LNBF setup to duplicate his C-Band performance.
When I go to do what he has done here on my P* dish, it likely won't work the same.
