TNAP 6 for Edision: Yes or No?
cyberham
6,057
5,085
British Columbia
Short answer is Yes! I now have image slots on my Edision Mio+ filled with two TNAP 5.1 and one TNAP 6 image. I am slowly migrating over to TNAP 6 but I keep TNAP 5.1 ready to use at any time just requiring a quick reboot of the Mio+. One of the reasons I still use TNAP 5.1 is because I haven't yet blind scanned all satellites for TNAP 6.
Some reasons I like TNAP 6:
  • Supports Tuner C on my Mio+ to use for the Hauppauge 950Q USB dongle for OTA. My most current version of TNAP 5.1 does not support this dongle. This is a known problem on more recent versions of TNAP 5.1 that won't be resolved.
  • Has a driver selector plugin so I can switch easily between no-T2MI, T2MI, and T2MI with low SR transponder support drivers. This is important so you can improve blind scan speed and accuracy.
  • Youtube videos play.
  • Has a plugin that easily and automatically creates IPTV bouquets matching any genre, country source, language you choose. If you have a fast Internet connection, IPTV arguably provides better/more entertainment than satellite these days. It all depends on your viewing preference and habits.
  • Has a plugin that supports creating a Pluto TV bouquet.
  • Comes preloaded with ALL satellites in the world with their transponders already configured. You can, of course, update the satellite and transponder lists as you wish. Actually, some satellites may be missing but most satellites across Europe, Asia and North America are included. Mood Music channels on 101W Ku are included too.
  • The image is fairly stable now.
  • Blind scan can be fast and accurate! If I use the no-T2MI driver with the MIS tp switch at OFF, then blind scan speed rivals my formerly-preferred GT Media V9 Prime. The different drivers can give dramatically different results so you need to use the driver that suits what you're doing.
  • You can easily copy an entire scanned-in-satellite with all channels over to User bouquets in one action. It's so easy and quick that this is how I create new User bouquets. I copy the entire satellite's list of channels and just delete the channels I don't want in the bouquet.
  • TNAP 5.1 is finished in the sense of support. TNAP 6 is now the only TNAP version being supported.
  • The TNAP 6 support site (legitfta.com) is now updated and stable.
TNAP 6 is like a Sony TV. After you obtain it, then you start to discover its good engineering and features that you may not have been aware of before obtaining it.
cyberham
6,057
5,085
British Columbia
... I was staying with 5.1 was the low bitrate driver.
Unfortunately, when I used the T2MI Module with Small Symbol Rates driver the results were terrible on a blind scan of 117W C. That driver produced only 26 tps. I only ran this test one time. But the No-T2MI Kernel Module produced 55 tps. I ran this again today and I believe I got 57 tps. So I'm sticking with the latter driver. A good scientific test suite using these different drivers in different situations might be up your alley.
Brct203
1,558
1,708
Connecticut
hahaha you know me well! Yes I shall run some tests... I think 117W is indeed an interesting test subject. 40.5W is also an interesting one, as it has some T2MI transponders, but it's overall a bit weak, so results do vary because some TPs are just around locking threshold
norman881
780
273
Washington State
How do I enable neutrino mode?
Jim S.
When someone asks you if you're a god, you say yes
5,865
1,673
FN11od
If you're talking about legacy-style (or as I like to call it, sane) channel navigation with the arrow keys, Menu>Setup>System>GUI Settings>User interface. There are two entries there, "Enable 'neutrino' style zap controlling" and "Enable 'neutrino' style channel select controlling" I have no idea what the difference is, because I only remember one of them being there the last time I looked, and I thought "zap" was Enigma-speak for changing channels...
DISCLAIMER: I'm not using the default skin, and I don't know if entries in this menu can be varied by the skin.
norman881
780
273
Washington State
I treied all 8 GUI skins and did not see the neutrino choice. Which skin are you using? Thanks for the response. (and you too cyberham)
Jim S.
5,865
1,673
FN11od
I'm using one called Copper-FHD, which is not in the TNAP repository. I don't remember where I downloaded it a few years ago.
Maybe we should ask El Bandido on the official TNAP forum? I seem to remember that Neutrino-style controls were the default in TNAP 5.x and below, I'm not sure why it would've changed.
cyberham
6,057
5,085
British Columbia
Guys, thanks for enlightening me. I thought norman881 was joking in Post #9. I've not heard the term 'neutrino' other than the scientific particles.
I am using the PLi-FullNightHD skin. I find if I switch ON the 'Enable neutrino style channel select controlling' that my remote control functions like in TNAP 5.1 and earlier. I like it this way and will leave it.
I had started to adapt to TNAP 6 and was getting used to the new remote control functions. But why change if we can have what we're used to?
Added: I also switched ON 'Enable neutrino style zap controlling' to make it like TNAP 5.1.
Brct203
1,558
1,708
Connecticut
Well I can confirm what you said... Take a look at the attached reports. Note that the duration indicated is for the blind scan part only, and does not include the service scan part The results are a bit inconsistant but still some hints:
on 117W, great results with TNAP6 using the regular non-T2MI driver, but that means no low SR transponders. The blindscan was fast and got most or all transponders. However switching to any of the other drivers gave very degraded results, missing many transponders without even finding the lower SR ones
TNAP 5.1 did MUCH better, with acceptable blind scan times with any of the drivers, and those supposed to work for low SR did find them (non-T2MI still the fastest)
Now on SES6@40.5W, the results for TNAP6 were acceptable with the T2MI , non-T2MI and the 700 MHz driver, but very slow with the Low SR driver. They were quite similar with TNAP 5.1. Why that low SR driver was so slow is a bit of a mystery to me, since the 700 MHz is also low SR and did much better (albeit slower than the non-T2MI). There are several T2MI transponders on that satellite but only one of them (Trece, Trece+ on 4000MHz) is strong enough for reliable reception on my dish (because of the sidecar LNBF for circular). It was detected by all drivers including the non-T2MI one, but of course only the T2MI drivers could actually scan in the services.
Now to be clear, I get overall mediocre reception of 40.5W, so blind scans always yield disparate results, since many TPs are near the threshold. As for 117W, I get a bit of 5G interferences in that direction, and that might have some influence on the channel count, but still we can see a clear pattern
Other than that, TNAP 6 works perfectly with my Hauppauge 950Q ATSC dongle, and seems very stable
Jim S.
5,865
1,673
FN11od
Neutrino is another interface that, like Enigma, runs on top of a full-blown Linux system, but appears more like a simpler STB interface. If I remember rightly, some variation of it shipped with the AZbox.
I actually found several open-source Neutrino projects that claimed that you could build them for the Edision, and since my PC is fast and capacious, I tried it. (You have to install a full set of compiler tools for a different CPU architecture, then build the entire Linux OS as well as Neutrino itself.) However, installing the resulting image in a multi-boot slot resulted in a hung box. I suspect that you have to flash the image as a raw disk image, wiping out the Enigma multi-boot capability, which I'm not willing to risk.
Jim S.
5,865
1,673
FN11od
I concur with what you said about the blindscan only being accurate with the non-T2MI driver. In addition, unless it's changed from TNAP 5.1, the non-T2MI driver is the only one that doesn't randomly shut off the LNB power after a blind scan, or when coming out of standby. Nobody seems interested in fixing this for some reason. (To be clear, I'm not blaming El Bandido -- I found people reporting the same thing on a European OpenPLI forum.)
Strangely, I seem to recall that with 5.1, it was the T2MI driver, not the non-, that was more accurate in blind scan -- although maybe not as dramatic a difference as in 6. (I should mention however that a lot of my tests took place on 99W Ku, which some days just seems impossible to scan accurately for some reason, and on 87W Ku, where Louisiana PBS just seems to disappear at random, so they may not be accurate...)
norman881
780
273
Washington State
I'm finding it exactly where Jim said it was, in TNAP 6 using the GlamourAuraFHD skin
items # 6 and 7 in the list of settings
Problem solved. I did not see the neutrino option settings until after I did a factory reset and a clean install. Thank you all very much!
Jim S.
5,865
1,673
FN11od
I think my Mio (no "plus") is staying on 5.1 for a while. I've had no end of blind scan problems with 6.0. It misses transponders frequently, even using the No-T2MI driver (which is the one I'm also using on 5.1, due to the others having problems with dropping LNB power which I've mentioned before.)
I did bring this up to El Bandido a while ago, and sent him scan logs from both versions. All he had to say about it was that some of my signal levels were marginal. Which they may have been, seeing as how my motor has slop and I had a never-ending sequence of wind storms last winter and spring, BUT, that DOESN'T explain why one version works reliably and one doesn't!
Last night I did a fresh install of the very latest 6.0, keeping no data from the other installation. Straightaway my very first scan only found two transponders, on a well-populated satellite. Rebooting fixed that, but it still didn't pick up everything every time. This despite claims that he programmed in a reset of the tuner before blind scans to try to alleviate the problem.
As further proof, I plugged in my old Freesat box, and it performed flawlessly, other than locking up on good old 99W Ku, which I've given up on using as a test for anything.
Edision OS Mio+ TNAP 5.1 Service Reports
