Andrews 4,6m
Magic Static
7,498
4,853
Montana
It seems to me those actuators have some high power motors on them and consume as much energy as a major household appliance. What kind of cabling are you going to do with the foundation? Internal conduits or all outside?
RimaNTSS
899
968
Riga
I cut the hole in the metal plate. Will let plastic pipe ~75mm (red lines) go through concrete and enter inside pedestal mount. I do not care about electricity consumption.... as will turn antenna very very seldom, and also possible to turn it by wrench, I mean mechanically. IMG_20160607_150244 (Custom).jpg IMG_20160527_153618 (Custom).jpg
Magic Static
7,498
4,853
Montana
Very nice work! I'm liking how this project is turning out :) I would put some eye bolts in a couple of strategic locations to use for winching points and tie downs when working on the dish.
Reactions: phlatwound
RimaNTSS
899
968
Riga
If I need eye bolts I can add them later to existing platform. But, by now I do not see big need for winch, as I was removing this antenna from previous location without any winch, and I think I will be able to install it back same way.
RimaNTSS
899
968
Riga
I was told it is about 12000kg. If was mixing myself, I would be still mixing till 25th July :biggrin. Of course, truck came and filled it up. That is why I digged couple of holes in the ground 50cm wide and 125cm deep to use any possible left overs of concrete. Those 2 holes are also full with concrete now. Will use them for stand-alone antennas, of course. :angel2
KE4EST
SatelliteGuys Is My Second Home
Staff member
HERE TO HELP YOU!
27,083
7,410
EM75xb
Are you gonna paint the panels any special color?
Equipment for Peace TV on Galaxy 19
Free LRIT/HRIT software for Goes 16
