Comments from a newbie to FTA
Even with said LNB, isn't a receiver capable of
tuning lower symbol rates and more precise frequencies still required?
Yes. It is a combination of a capable receiver and frequency stable LNB. The AFC process for most tuners is quite adequate, but the minimum SR handling is the limiting factor. A PLL LNB teamed with an external TXCO reference source will provide the best stable signal for decoding.
Unfortunately, aging Invacoms have proven to be quite thermal frequency unstable.
Reactions: comfortably_numb
Locked a low SR on the Amiko on 87 KU-
This is using an Amiko non-PLL LNB, which is remarkable. However, I do not know the audio PIDS for this feed, which appears to be the "Family Life Ministries" mux.
Reactions: byron
The fact that the problem is solved when you go to 105 then back to 101 sounded like a potential motor issue, but I don't know anything about C-band actuators.
I think I figured this out: I think my 101W C band settings under "Antenna Setup" didn't specify the diseqc command. For some weird reason I could flip to 105W (which engaged the correct diseqc commands in the settings), and when I switched back to 101W I guess the receiver "forgot" that it wasn't supposed to not send a diseqc command (yes I realize this wording is confusing).
Cn, Just make sure you adjust the difference between offset dish that are used to do it on Ku band, now you got focus point dish in a C band world your angle look will be little higher so just adjust the difference between offset and focus dish pointing to the birds.🙂👍 :hatsoff
Low symbol rate finds on C-band. All of these were located using a V9 Prime with the T2MI toggle "ON."
97- 4022 V 373
97- 4050 V 444
99- 4161 H 1040
99- 4162 H 1040
Radio Signals
Best 4x1 diseqc switch?
