5g interference
iBoston
2,778
2,406
North Central
I have a question. I am having jittering/stuttering across the entire TP spectrum. I'm seeing it at 4060 and 4100 and even higher. Is this a normal thing. I would have thought you would only see it on the lower frequencies closer to what was taken from Cband a few years back. This problem crept up about 3-4 months ago, and before i just throw money at the problem by investing in a filtered LNBF, i want to do a bit of checks and balance with you folk.
My stuttering appears as often as every 20-30 seconds and sometimes it doesn't happen but every 20 minutes or so. I seem to have solid locks on the signal. This is on a smaller 8' Solid Cband dish. I swapped out a different LNBF. Same result.
If the advice is to get a new filtered LNBF, would I be looking at the Titanium RED or BLUE band pass filter?
5G carriers DO NOT only affect satellite signals located on the same frequency.
What does this mean?
If the LNB band pass frequency range allows signals from interfering carriers (such as 5G N77 and N78 low band & High band) to be downconverted and amplified, these strong 5G signals can affect the reliable reception any transponder within the band pass frequency range.
Why does this happen?
LNBs and LNBFs downconvert and amplify in a block (Low Noise Block) of frequencies, which are sent down the coax and tuned with the satellite STB. Filters are placed on the incoming satellite signals and the outgoing signals to determine the frequency range that will be passed and the ranges that will be blocked. If a strong signal is received within the frequency range that is allowed to pass, the LNB's automatic gain control will reduce the amplification gain across the entire block of frequencies to prevent over-amplification and receiver overload.
The STB then receives a poor signal with a reduced Signal to Noise Ratio. The STB then applies Forward Error Correction to attempt to correct the missing and damaged data in the Transport Stream. The break-up and /or loss of the video and audio happens when the number of errors become too great and the FEC no longer is able to correct and decode. When it gathers enough data to decode, then the video and /or audio is temporarily restored until the errors overcome the ability to correct.
I ordered the LNBF. I hope i can post all issues resolved... That TitaniumSatellite is quick with shipping. :hatsoff As soon as i get it, ill pop that new toy into position and post my results...
Thanks for the edumacation Titanium and thanks for the feedback comfortably_numb :)
Did you use the "satguys save" code in the promo code box, for 15% off the order? As far as I know, Brian has always honored that promo code, and it's still active.
I wonder if I need an LNBF with a tighter bandpass since 4032V15201 on 117W intermittently drops to zero CNR but mostly stays at 14 dB. Happens on both my 12 footers. I don't remember which Titanium LNBF I have without getting out a ladder to look at the LNBF.
Do you still have the email from Titanium with the receipt?
Reactions: FTA4PA
Okay, i got LNBF last evening. USPS has been getting worse over the last few years because they keep closing distribution sites. Rural Living - The price i pay for living in Paradise. I just hooked it up. It will take me a couple days to see if the interference issues are resolved. Ill post back.
All good now.. No more glitching.... I have one more Cband dish with NO filter on it. Not getting any glitching on that LNBF as of yet, but then 3 months back, i didn't have it on the current one i just swapped. Thanks Comfortably_Numb and thank you Titanium. :victorious
I have my C-band dish operating between 40°W and 133°W now.
Even though I use a blue filter LNB, I still experience some pixelation on certain transponders at 125°, 127°, 131°, and 133°.
Additionally, I can receive 3.9-4 GHz transponders at 55°W and 58°W.
I suspect there is a 5G tower on the west side of my dish.
Using a Blue filter LNB without the Blue waveguide filter?
I guess the C140 was a waste of money. Looks like I won't be watching much C-band anymore.
  • Sad
Reactions: FTA4PA
Are you SURE your issue is 5g interference, and not something else going on?
Of course IF it really is 5g interference, maybe your dish is pointing right at a node really close to your dish, OR, your local 5g is out of band. You'll need a spectrum analyzer to check all that.
IF you have a 5g mobile phone, how strong does the 5g signal on that show at your dish site? IF it's 5 bars at all times all around it, there might not be much you can do to fix it.
Auction of the Upper C-Band Frequencies
Testing the Titanium C140 and C240 5G Filtered BLUE LNBFs
