Edision mio+ 4K Tuner (?) issue
4Him
20
Italy
Hello everybody,
I'm from Rome, Italy.
I hope someone could help me in this, because I'm going mad.
First of all sorry for my bad english:)
I've Edision Mio 4K+ connected to a H-H Rotor and TNAP 6
Tuner A fails if I switch from a satellite channel to another one of the same (strong) satellite position, in particular from Horizontal to Vertical trasponder.
also It fails if I watch a satellite channel, switch to iptv, return to the original satellite channel.
It happens with various images I've tested.
It does not happen with other enigma2 satellite receiver.
TNAP Enigma2 image has "Tuner driver selector" and you can choose 4 different driver:
It seems it works normally if you choose "No T2-mi driver".
But I need to use the t2-mi ready driver .
I kindly ask for your help because is overall a great receiver but I can't use it in this situation.
Thank you in advance.
Best regards.
Hello everybody,
Best regards.
My experience with TNAP 6 is that it's great with the non-T2MI driver but not so good with the T2MI drivers (missing lots of transponders on blind scans).
Did you try TNAP 5.1? Its T2MI drivers work very well. So my suggestion would be to install TNAP 5.1 in another slot and see if the problem persists, if you have not tried that yet.
I agree with Brct203. Try what he says first. Although TNAP6 is good, I still get unexplained things happening occasionally.
I have almost the same setup as you but I don't experience the issues you describe even when using the T2MI driver with TNAP6. How long is the cable from receiver to dish? Be sure the voltage reaching your dish LNB is correct: 19V on horizontal transponders, 13V on vertical transponders.
You may simply have a hardware problem. Have you had lightning in your area recently?
Reactions: Brct203
Another +1 on trying TNAP 5.1 in another slot before you waste any more worry on this issue. It's likely just TNAP 6 in current state.
I tried using it for a little, and ended up coming right back to 5.1 for stability.
This is a good case for why multi-slot capabilities come in so handy for testing things.
I haven't had a good experience with the T2MI driver in 5.1 either. It doesn't fail on simply switching polarities like the OP's system, but it will randomly fail after blind scans, and randomly fail when coming out of standby mode. There doesn't seem to be a set time period, but it WILL eventually fail if the box goes long enough without a reboot. Sometimes it's days, sometimes it's just hours. It's NOT a hardware problem, because the non-T2MI driver has no such issues.
I saw some discussion on this on one of the European forums, but there was no resolution. Everyone agreed that it was a driver problem, but then the discussion degenerated into an argument over which driver version was the current official release, and eventually it just stopped.
EDITED TO ADD: My Mio 4k is not a "+" version. I do not know if there are any differences in the driver for the primary tuner, but it is the same tuner, is it not?
Reactions: Brct203
May be kind of off topic but I have the version of 5.1 from TNAP Images installed in one of the slots of my mio4kplus. Unlike the versions of TNAP5 and TNAP6 I have installed, it does not detect the Hauppauge 955Q ATSC tuner. Anyone know where I might find a version of TNAP 5.1 that does detect the 955Q ATSC tuner (while ATSC 1.0 is still working)?
Reactions: norman881
Have a copy of 5.1 for the Mio4k+ on the HDD I can share.
  • Love
Many thanks.
I had read there was a version that supported the Hauppauge tuners but I couldn't find it.
The file has been saved to a couple of my NAS drives as well as the primary computer I use to access the Edisions.
Again, thanks. I appreciate your assistance.
sorry I can find just version 6 here, am I wrong?
Have you searched in Settings/Packages in the webif?
As far as images go. TNAP is kind of an idle image in a slot. I use it for finding signals below threshold.
I didn't get much on the tuner glitch but would suggest going straight from the receiver to lnbf and see if the issue persists.
I take it the dish is ku only. What lnbf? If it's just a 10500 LO unit. Don't forget to deselect Band in tuner setup.
If the lnbf is in fact a low/high band unit. Then Band is used.
The screenshot is from OpenViX. My favorite by far. TNAP drivers work with it ok. Although with the low sr driver, T2MI driver there is a bit of "chinabox syndrome" where with no or very weak signals the signal meter fluctuates into the red. Normally I use the factory tuner driver.
It's either signal strength or something else. Either image. When someone posts a feed in the low (600ish) sr range. I have problems snagging signal. If I ever do. Even after waiting minutes. Guess I could tap into the coax with a spec. analyzer and see if anything is actually there.
Who was it who posted the finding using the different TNAP drivers? Quite informative.
There are instances where I stream 4:2:2 channels to my streaming box. After some time going back to the receiver's HDMI port. The receiver freaks out and is balky as hell. Even using the remote to head to deep standby or reboot (don't ever just reboot...do a cold boot) is very slow if not simply unresponsive.
If you're a Linux geek I'm fairly positive you can CRON a reboot at a certain time. Like when the wifey keeps jabbing you when you snore to high heaven.
TNAP in itself is quite brilliant although some of the expected menu options and settings found "in your face" in other image is lacking.
As far as IPTV goes. Used very little. No real hang up's switching from satellite to it at all. The USA come-and-go M3U8 links are dodgy to say the least. Know wom-sayin'?
Hello everybody and thank you again for your kind help.
I have installed TNAP 5.1 the receiver works fine at the moment, but it is installed just "normal" tuner driver.
I have some questions anyway:
1) I've tried to install other tuner driver from "extra" but it seems it can not handle t2-mi also if I've downloaded both "t2-mi tnap mod" and "avl t2-mi" version
2) I need to install usbserial to use my usb hub do you know how to do it?
3) I'd like to change boot logo, uploading another picture, do you know how?
Thank you again, best regards
1) Not even sure if I've ever been able to watch a t2mi channel here in the usa. When I do try to scan the tp's and get channels, they are black with no audio. Didn't check for encryption methods, etc.
But the regular vix tuner driver scans lots in.
Ex:
<sat name="121.0W C-band Galaxy 31" flags="1" position="-1211">
<transponder frequency="4010000" symbol_rate="15000000" polarization="0" fec_inner="3" system="1" modulation="2" />
<transponder frequency="4020000" symbol_rate="30000000" polarization="1" fec_inner="2" system="1" modulation="4" is_id="18" pls_code="1" pls_mode="0" />
<transponder frequency="4020000" symbol_rate="30002000" polarization="1" fec_inner="2" system="1" modulation="4" is_id="0" pls_code="1" pls_mode="0" />
<transponder frequency="4041000" symbol_rate="29998000" polarization="0" fec_inner="3" system="1" modulation="2" />
<transponder frequency="4046000" symbol_rate="30000000" polarization="1" fec_inner="0" system="1" modulation="5" is_id="18" pls_code="1" pls_mode="0" />
2)
3) Be extra careful with boot logos. They must be the exact size and format. A link to assist is here:
Boot Logo
If you're 100% sure it's correct. Cases like openatv, vix and other images will change the factory Edision logo when you flash an image. Simply preparing a USB flash drive for image flashing. Deleting all files from the drive except for "splash...bin" and the "force" file. Splash.bin being your boot logo. Power down the receiver. Pop the drive in. Boot it. Select OK. That's it.
Any doubts of the receiver recovery of using an incorrect boot logo. Well....:If it happens the receiver will be semi-bricked. Requiring wire soldering and serial console commands. So. Be 100%. You can copy the splash.bin file from an image and change the .bin extension to .png and open it in something as simple as Paint. Look at the pixel dimensions. If they match. Good.
Reactions: primestar31
Any way to get rid of awful Anime image in TNAP?
