Edision reconnect problems
$585.00
TVHabit
60
15
Southwest Desert
I decided to reconnect my Edision OS mio 4K to my dish after it has sat in the closet for a few years. I was able to get it operational when I first bought it in 2019 but went with another receiver at that time because of my slow learning curve. So today I decided to give it another shot and reconnected the receiver and it powers on fine - everything looks good EXCEPT it flashes on and off, on and off and won't stay still. Kinda like a new puppy? Anyway, does anyone have a suggestion? I tried turning it off and on using the remote and unplugged it several times but still it flashes on and off.
I carefully reboxed it when I put it away so it's just been sitting for 3-4 years. I wonder if it's toast?
Do you have another power supply of the same rating to try? Mine did that a while back - display on screen and on the receiver flashed on/off - then it finally went out all together. I figured it was toast but a new power supply I had here fixed the issue. ;)
I agree with this being most likely. Though IF by chance it doesn't fix it, also try disconnecting the coax going out to the dish and see if it stops flashing.
I never thought about a defective power supply. I don't have another one with the same specs so it'll have to wait. Thanks for the suggestions. This site is a great go-to place for answers on the hobby
I'm not sure what you're asking but I bought it originally to upgrade my BUD at my cabin. It was a nice receiver but I did not have internet access there to ask questions so I went with an Amiko instead.
I don't understand the purpose for an Edison. What is a BUD & Amiko? I will research more in Google.
What does this Edison device provide for you?
At the time it was released (has it been 5+ years ago now?) it was a top of the line satellite receiver for KU and C-band hobbyists. It can stream video across your network, load multiple Enigma (Linux) images, stream IPTV channels and more. It's still a solid receiver, but becoming more difficult to find and used units can be expensive.
Reactions: comfortably_numb
Neither one. I purchased an Amiko and am using it. Also a good receiver
What is the rating on your power supply for your Amiko? I know it should be 12V but not sure of amperage though. You could try subbing it in to see if it corrects the issue with your Edision. If so, then you could be sure that's the problem and obtain another PS for your Edision.
It's a +12 volt, 2 amp power supply. Very common. You likely have several of them laying around the house. If not, Amazon likely sells one, just make sure you verify the barrel size is correct.
comfortably_numb gave a good answer. There are still new models available from overseas but just not the ones those of us using now have. To keep it short, I would say the Edision has the broadest set of capabilities of any hobby satellite receiver available. Whether you need or want all of this is your question to answer for yourself. The learning curve is steep when you first begin using it. But once you learn it, it's fun for a hobbyist to use.
Got it thanks.
Reactions: FTA4PA
Update
Bought a new power supply and swapped it with the one I'm currently using but to my disappointment, it is still flashing on and off. Not knowing a lot about electronics-seems it has another issue. I'm guessing a capacitor but that is beyond my pay level.
Plus a wind storm last night screwed everything up. Trying to get it reset but it's one of my least favorite things to do.
Just an update and venting...
Update
I had the flashing display issue happen to our Edision. I found that the KU coax had been damaged and replaced it. Fortunately the receiver was not damaged by the shorted cable and a new power supply fixed things.
Update
Disconnect EVERYTHING from the receiver, with the exception of the power cord, and the HDMI cable going to your tv set. See if it powers up after that. Could be a coax line or something shorting out.
Update
just wondering, how old is the TV you're connecting to? Older TVs often have problems displaying 50 Hz frame rate (vs 60 Hz for regular North American video), and depending on the image you're using in the OSMIO4k or what it was set to last time, it might be defaulting to 50Hz. Hopefully you can see enough between the flashes to navigate to Menu-Setup-Audio/Video-A/V Settings and change the 3rd row to 60 Hz
Also, my recent LG TV often flashes if I set the receiver resolution to 2160p. Works fine at 1080p. Not sure if it's a TV problem, a receiver problem or a cable problem. But since there's no more 4K channel, I just leave it on 1080p
the other advice about disconnecting everything except power and HDMI is also a very good thing to try
OTHER GT media v9 / LNB settings / signal intensity issues
AMIKO Need Amiko ALI editor software
