LET'S TALK ABOUT SWITCHES
techristian
14
6
Windsor
Ever since I have had an S2 switch and 2 dishes I thought the rule was the same for 4 way/ 8 way switches. C band sats TURN OFF 22K, KU band turn on 22k (in settings) but according to some sources that isn't true. 22k should be turned to AUTO for 4/8 way ACCORDING TO SOME SOURCES. Even though I got most of the bugs out, some funky things are happening. I'm not getting all of the channels. I DON'T HAVE AN AUTO setting for my 22k tone. I have been doing this more than 15 years and so I'm baffled.
My AMIKO doesn't have a auto setting for 22k. Sometimes it lights up BLUE and sometimes it doesn't.
Dan
The only time the AMIKO lights up blue (22k off) is when you have setup a universal LNB. Only if you have a 0/22KHz switch between your LNB and your 4 or 8 port DiSEqC, and have another LNB on the other side of your 0/22KHz switch, do you need to set the LNB to 22k on or off. (There is the one exception, if you set up a universal to only scan one section of the bands it can scan).
Otherwise, there is no point in turning on the 22k when using a 4 or 8 point DiSEqC switch, in fact, it just add extra unnecessary commands to selecting ports.
techristian
To add:
General rule: the settings for the switching signals by your receiver should match the needed signal for the switch(es), and the needed signal for the LNB.
Your "some sources" will probably follow that rule, matching the exact setup they serve; which maybe does not match your setup at all.
Your opening post does not describe your own setup in any detail. Without detail, we can only guess and maybe make wrong assumptions about what is needed and/or possible.
So for more detailed advice, I guess more info would be needed about the LNBs in your setup, and the types of (legacy) switches: tone switches, toneburst switches, voltage switches, multiswitches, diseqc switches (level x.0, x.1, x.2, or maybe multiprotocol).
Greetz,
A33
Edit: if your only problem is that you cannot find the "auto 22kHz" setting for correct (Ku) band, you probably didn't define the setting for universal LNB or dual LOF setting. That should allow auto 22kHz.
That blue light is what trips a lot of people up — on the Amiko it is just telling you the 22kHz tone state for that entry, not which DiSEqC port is selected. The switch itself picks the port from the DiSEqC command, so the tone does not switch dishes for you.
A setup that works for me with a 4x1 / 8x1 DiSEqC switch is:
- Set the DiSEqC 1.1 port in the receiver to match the physical port on the switch, one satellite per port, and leave 22kHz OFF for each entry unless that LNB actually needs it.
- The only time the tone matters is for a universal Ku LNB, where it switches the LNB between its low band (9750 LO) and high band (10600 LO). If your LNB type is set to Universal in the Amiko, that band switching is handled through the LNB setting — you do not need to force 22kHz ON as well. For a standard single-LO LNB, or for C-band (usually 5150 LO), leave it OFF.
- If some satellites scan in and others do not, check the LNB type / LO frequency first, before blaming the switch. A universal LNB entered as Standard, or vice versa, will scan some transponders and miss the rest.
The quickest way I sort this out is to bypass the switch: run one LNB straight into the receiver, blind scan that one satellite and confirm the channels are there, then put the switch back in, add one satellite at a time, and scan after each one. If a satellite works direct but not through the switch, swap its cable with a working port — that tells you in a minute whether it is the port, the cable, or the settings for that entry.
I am using a single Spitfire LNB on 97 W ku. On that one with 10600 I now have 22k on. With the other 2 KU LNBs (at 10750) 22k off. Things working good except for 97W 12028H 22000
You mean the spitfire ASC321 LNB, with L.O. 10.750?
No the Spitfire Elite. I have 2 more on a dish that I'm no longer using.
Ah. Google didn't give me that one, at first.
So you indicate that you have a problem with only one frequency on 97W now, and this might not be a switching problem?
Have you tried receiving with a LOF of 10596, and a LOF of 10604; in case the LNB LOF has drifted?
That's a thing that I often check first, when having problems on just one frequency.
Greetz,
A33
Why my FTA box stopped working?
