Comments from a newbie to FTA
OK. Using an Amiko MINI HD265 with V1.6.06 i was able to lock on to 3938 V 674 and then scan in these 5 Radio Channels. I can confirm these are ITC and working audio. I have Signal 98 Quality 81. However, there is a little breakup to the audio no matter what i do, as if i need a bit more signal
88.9 Noticias
La Comadre
Match
MIX
AMOR
Radio Felicidad
I don't know if this has anything to do with it, but I'm using a Maverick PLL LNB for the low SR feeds. This guy is selling them for less than $15.88 free shipping:
it might be significant... I think I remember a conversation a few years ago involving several forum members (I think you were invoved) where we were experimenting with SDR and the software demodulator that is available online, and the Maverick appeared to be the key to success.
I have one, I will try to swap it soon and see if that gives better results.
Not only that, but we discovered last night that it helps a lot if the dish and LNB are really "dialed in," as it seems the stronger the signal, the easier the receiver scans it in. That might seem to go without saying, but compared to normal video feeds with higher symbol rates, the Edision "likes" a really strong signal to be able to scan the services in these feeds. We got the SNR up to 13.4 db on WPR last night just by tweaking the LNB. The audio was nice and clear with no breakups, even after an hour of listening.
My Maverick LNB significantly improved upon the Edision LNB, the Geosatpro IIRC was somewhere in between Maverick and Edision (all on a 90 cm dish)
V9 Prime receiver does support U.S. CC!!
Danger Pay?
