5g interference
I guess the C140 was a waste of money. Looks like I won't be watching much C-band anymore.
Might not even be 5G interference. What is the CNR on 4032V15201 on 117W when it is decoding reliably? As it is DVB-S 5/6, should decode reliably to approx. 6.5dB C/N. If your CNR doesn't have adequate headroom above 6.5 dB (minimum recommended C/N), other minimal factors may be affecting the reception.
5G interference is usually exhibited as fluctuation of lock/unlock (steady video and sound then microblocking and stuttering audio repeating cycle) as the Forward Error Correction (FEC) attempts to gather enough uncorrupted bits to correct the errors and begin decoding again. I wouldn't expect the CNR just to drop to 0dB and remain.
Try shifting the TP frequency to the published 4031 MHz +/- 1, 2 or 3 MHz. This frequency is very close to the filter bandpass, so the C140 attenuation slope is typically 25db and ramping up near the filter edge.
If this is the result of 5G interference, you might need a tighter filter such as an inline mechanical waveguide on a feedhorn in addition to an 4000-4200 MHz BPF LNB and maybe even build a RF fence to block the source.
15.1 dB with occasional drops to 0 and back to 15.1 dB
I tried higher freq transponders on this sat with same results. I have this issue on other sats (99, 101, 103) also.
Don't know if it's worth the expense to change to a LNB/servo or dual output LNB. I have 2 C-band antennas exhibiting this problem.
Reactions: Titanium
I live practically right next to two 5G towers and when they went live they wiped out everything on C band. I installed the C140 and have watchable signals again with one exception; aircraft radar. I'm in the flight path for two major airports and when the planes turn around over the pacific and head back towards land the radar signals completely overwhelm the LNBF. Watching it on a spectrum analyzer is quite the sight to see. Do you have any radar installations in the vicinity?
Reactions: FTA4PA
None that I know of.
This was very interesting to find. A NOAA weather station outside of Philly. Aimed most probably at 121W on the NOAAPort tp.
Never really saw a shield on anything but microwave link dishes on towers.
Pretty cool, huh!
Reactions: texanboy
Substack about Bob Cooper
Kijiji, eBay, and Craigslist dishes for you to take a look at
